regular or synthetic oil for turbo?
Old 01-29-2007, 03:53 PM
* B A N N E D *
Pnoyej6's Avatar
Default regular or synthetic oil for turbo?
which is better for turbo? Im using regular 10w40
Old 01-29-2007, 03:54 PM
DaveF's Avatar
Default Re: regular or synthetic oil for turbo? (PnoyEj6)
it doesnt matter, just make sure you change it more than regularly.
Old 01-29-2007, 04:05 PM
psikotc's Avatar
Default Re: regular or synthetic oil for turbo? (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">it doesnt matter, just make sure you change it more than regularly. </TD></TR></TABLE>
Old 01-29-2007, 06:18 PM
Zeusfire69's Avatar
Default Re: regular or synthetic oil for turbo? (psikotc)
I've always used semi synthetic...best of both worlds...
Old 01-29-2007, 07:42 PM
CivicVX94's Avatar
Default Re: regular or synthetic oil for turbo? (Zeusfire69)
i always use synthetic b/c supposedly it can withstand higher temps before it breaks down....although that could be marketing bs..idk
Old 01-30-2007, 01:48 AM
bart2546's Avatar
Default Re: regular or synthetic oil for turbo? (CivicVX94)
I've always been a big fan of synthetic myself. It basically builds up an extra layer of protection on the cylinder walls, so why not use it to lubricate and extra-protect the turbo IMO.
Old 01-30-2007, 05:08 AM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicVX94 &raquo;</TD></TR><TR><TD CLASS="quote">i always use synthetic b/c supposedly it can withstand higher temps before it breaks down....although that could be marketing bs..idk</TD></TR></TABLE>
its not.. there a reason why only synthetics offer wider range multi visc. oils.. therea are couple decent conventional but its worth the money for full synthetic
Old 01-30-2007, 09:47 AM
* B A N N E D *
Pnoyej6's Avatar
I HEARD SYNTHETIC FINDS IT WAY THROUGH THE SEALS AND STARTS TO LEAK
Old 01-30-2007, 09:56 AM
92LSVTEC's Avatar
but if your going to change it all the time.... regular oil... unless you are an out of control baller and can afford synthetic
Old 01-30-2007, 11:14 AM
k24em2's Avatar
Default Re: (PnoyEj6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PnoyEj6 &raquo;</TD></TR><TR><TD CLASS="quote">I HEARD SYNTHETIC FINDS IT WAY THROUGH THE SEALS AND STARTS TO LEAK</TD></TR></TABLE>
YOU HEARD WRONG.
Old 01-30-2007, 04:14 PM
sfgreddiedsi's Avatar
so synthetic is better? ahahah
Old 01-30-2007, 05:48 PM
MrParks's Avatar
Default Re: (sfgreddiedsi)
support companies that support drag racing
i use castrol gtx for as long as ive known, its just more costly for me i change my fluids every 3 passes
Old 01-30-2007, 05:58 PM
jdmsiR20's Avatar
Default Re: (MrParks)
personally use synthetic...
just for the fact that i sometimes miss the 3k oil change mark.
Old 01-30-2007, 11:37 PM
IceySC's Avatar
i was using synthetic blend in my built allmotor car ran great
Old 01-31-2007, 06:25 AM
CivicVX94's Avatar
Default Re: regular or synthetic oil for turbo? (IceySC)
i guess i'll be the first to say it then, royal purple ftw!
Old 01-31-2007, 06:45 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicVX94 &raquo;</TD></TR><TR><TD CLASS="quote">i guess i'll be the first to say it then, royal purple ftw! </TD></TR></TABLE>
this is what we run in our dragcars. Royal Purple Racing 41 doesnt get contaminated nearly as easy as compared to other oils(we are on alcohol also) and our oil has never come out looking like coffee
its always purple and smells good too
always run castrol GTX in my street beater
Old 01-31-2007, 12:28 PM
Dueceification's Avatar
i run synthetic on all my cars turbo or no turbo Mobil1 is only 20 bux at walmart
Old 01-31-2007, 01:04 PM
CivicVX94's Avatar
http://www.cincinnatistreetrac....html
i stay safe and stay away from mobil1 after i read that article and skimmed the link he posted....
Old 01-31-2007, 04:07 PM
95dc2teg's Avatar
Default Re: (CivicVX94)
castrol gtx full synthetic here. but i still change my oil every 3000 miles anyways.
Old 01-31-2007, 05:53 PM
Mykizism's Avatar
on my car h22 with a gt3563e, the turbo didnt spin at idle with 10w-40 conventional oil, after 1k miles on my new motor, i switched to mobil 0w-40 synthetic.. the turbo spins at idle now.. lol i dont know if thats relevant or anything, just wanted to share that..
NosCivic01
10-18-2006 09:41 AM
builtboostedteg
09-21-2006 04:18 PM
speedemon
08-11-2004 05:49 PM
zbower7
03-25-2004 10:57 AM
B18B1DOHC
09-22-2003 09:23 AM
Quick Reply: regular or synthetic oil for turbo?
