Power FC Boost control kit
Old 05-27-2003, 12:26 PM
swlabhot's Avatar
Default Power FC Boost control kit
I'm going to be getting the PFC for my Turbo ITR soon. In order for it to control boost, do I HAVE to get the Apexi Boost Control Kit for it in order to map it for boost? or can I still use an MBC? Which one do I get as it is not actually listed for the ITR as its not an oem turbo car.
Can someone confirm that if this solenoid is the SAME as the one used for the AVC-R? If this is the case, it might be worth paying that little extra for the AVC-R and use the solenoid valve instyead of just getting the boost kit seperately as its nearly the cost of the AVC-R itself?
Old 05-27-2003, 12:42 PM
MiraiZ's Avatar
Default Re: Power FC Boost control kit (swlabhot)
you only need the PFC boost controller only if you want to control the boost using the PFC commander...otherwise you don't need it...you can use anything to control the boost. The AVC-R's selenoid is different (I think)
Old 05-27-2003, 01:03 PM
ZentraediEK's Avatar
Default Re: Power FC Boost control kit (MiraiZ)
Miraiz is correct, you can use any boost controller you want. but if to use the commander you need the boost control kit.
Modified by ZentraediEK at 9:54 PM 5/28/2003
Old 05-27-2003, 01:20 PM
swlabhot's Avatar
Thx! Looks like thats money off the hook for the DataLogit instead
Old 05-27-2003, 03:06 PM
slywfbpsi's Avatar
Default Re: Power FC Boost control kit (ZentraediEK)
carboy, xs, and spi told me that the solenoid was the same in the pfc boost kit and the avcr. They recommended that I just use the avcr. My thinking is, if I can use the pfc to control boost for an addition $180 for the boost kit, why spend $400 for the avcr with has the same solenoid?
Old 05-27-2003, 05:32 PM
turbotypeR@SPEC's Avatar
Default Re: Power FC Boost control kit (slywfbpsi)
i talked to the guy who tunes the pfc at xs and he told me that it sucked and i should get a different controller instead.i was not going to argue with him.i use a turboxs hpdbc manual controller with mine.
Old 05-27-2003, 06:05 PM
BoostinDC2's Avatar
Default Re: Power FC Boost control kit (turbotypeR)
yes the power fc boost kit sucks. im using an AVC-R with my power fc boost readings are a little off on the commander so get the boost readings off the AVC-R
Old 05-28-2003, 03:20 AM
Default Re: Power FC Boost control kit (BoostinDC2)
it is off in what way.does it read low or high and how much?
eflove
Engine Management and Tuning
08-05-2008 10:04 PM
NLR
05-02-2006 09:14 AM
vteec
02-27-2004 02:11 PM
Quick Reply: Power FC Boost control kit
