pcv block plug?
Old 10-28-2005, 12:52 AM
s2kkid's Avatar
Default pcv block plug?
im having problems with what appears the black stock catch can leaking from under the o-ring seal,freshly boosted b18c on 9:1 with even 180psi in all 4 cylinders(appears to be good) with no indicatinons of blow by.
is anyone having this problem? I was wanting to get a aftermarket catch can and get the plug to plug off the stock one because im tired of oil leaking out there.
ive beenreading on acceleration the pcv valve stops working- and oil is slung to the back of the block, and oil is pooring out and driping on my downpipe.
So i figured id completely get rid of the stock pcv box all together, plug the hole to fix my leaking isues, and use a catch can to relieve pressure that needs to be relieved.
Ive seen people use the z10 plug- where can I get it...?
Also Whats a good catch can setup I can get?
Old 10-28-2005, 04:10 AM
green_GSR's Avatar
Default Re: pcv block plug? (vtecluder97)
Check you O-ring seal again and make sure the O-ring is not crimped or torn.
Old 10-28-2005, 11:22 AM
s2kkid's Avatar
Default Re: pcv block plug? (green_GSR)
brand new.
Old 10-28-2005, 11:26 AM
mike1114's Avatar
google owns you!!!
http://www.z10eng.com/
Old 10-28-2005, 12:48 PM
s2kkid's Avatar
Default Re: pcv block plug? (mike1114)
lol i just had called them before i read this post.
the guy didnt seem like he wanted to answer my questions and was busy- ill ask them here.
Im leaking toward the z10 kit because:
1. My engine seems to be leaking at the stock pcv breather box hole badly- the cure to keep if from leaking there would to obviously be to seal it with the z10 plug-of couse ventilation would need to be done differently since the hole is plugged.
Where will the catch can attach to since that access hole is plugged- does it go somewhere else diferent?
2. I was also wanting to do a second one off the valve cover for aditional ventilation- can someone post a picture of a CLEAN upper valve cocer setup with the anodized fittings mounted to a second can?
Old 10-28-2005, 12:57 PM
Boofster's Avatar
Go Z10 with a moroso setup. The only way to get the Z10 is to call them. They are very busy but don't blame them.
Old 10-28-2005, 01:19 PM
s2kkid's Avatar
i was just wanting to see pictures and how it mounts- ill most likely go with them anyhow.
do the two lines hook in where on the nipples shown on this picture?
Old 10-28-2005, 02:47 PM
dfoxengr's Avatar
Default Re: (vtecluder97)
NAPA actually has a plug like that for like 5$, same size, i couldnt tell you the P/N but a search on here will get it for you.
Old 10-28-2005, 09:26 PM
s2kkid's Avatar
Default Re: (dfoxengr)
honda tech search is down for ever like always.
anyone got pictues of a valve cover setup too?
Old 10-30-2005, 07:12 PM
chadmasterc's Avatar
interested in this also
Old 10-30-2005, 07:14 PM
alpha's Avatar
Yes<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecluder97 &raquo;</TD></TR><TR><TD CLASS="quote">i was just wanting to see pictures and how it mounts- ill most likely go with them anyhow.
Yes. You cant see the other one in that picture. Here are some other pictures I took.
* The one you cant see
* The one you can see and the one you cant
Old 10-31-2005, 12:35 AM
BoostedCivicSedan's Avatar
Default Re: (0x64)
Damn John, now I know who can help me when I finally get my catch can setup... I'll buy you a milshake lol
Old 10-31-2005, 03:19 AM
kasso's Avatar
sorry to hijack... but how do you drain the oil back? in a non vacuum assisted catch can setup, u got those two lines off the back of the block runnin to a catchcan with a filter on top correct? how do you set this up to automatically drian the oil back into the motor?
Old 11-01-2005, 12:16 AM
Default Re: (kasso)
there shouldnt be much oil getting into it... The purpose of this is to ventilate crankcase pressure, so of course some can and will get in there, but not enough to worry about... The areas where the fittings are tapped into dont have oil running through them, just airspace...
Old 11-01-2005, 05:00 AM
mike1114's Avatar
Default Re: (BoostedCivicSedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedCivicSedan &raquo;</TD></TR><TR><TD CLASS="quote">there shouldnt be much oil getting into it... The purpose of this is to ventilate crankcase pressure, so of course some can and will get in there, but not enough to worry about... The areas where the fittings are tapped into dont have oil running through them, just airspace...</TD></TR></TABLE>
Untrue. These passage ways are the major oil galleys for the motor (they return oil from head to oil pan) There is a lot of oil going through them.
I have one port off the back of the block, the one to the left of the oil filter in the picture posted above. It fills my catchcan up in about 2 weeks.
My OTHER catchcan off the valvecover NEVER has any oil in it though. I do not have to drain it.
Old 11-02-2005, 12:28 AM
hondaapi's Avatar
Default Re: (mike1114)
Does someone have the partnumber of these things where you can put the hose on? I know HONDA sells them, but my dealer canīt help me without a partnumber.
Thanks
H4CRXSi
02-22-2010 03:53 PM
blakacintegra
05-12-2007 08:52 PM
johnzm
12-09-2004 10:14 PM
briq4
08-08-2001 04:47 AM
Quick Reply: pcv block plug?
