View Poll Results: which color?
painted black
66
68.04%
nice and shiney aluminium
31
31.96%
Voters: 97. You may not vote on this poll
painted intercooler or not
Im a big fan of having a nice shiny intercooler hanging in the front bumper, but I also like the black intercooler sleeper type look, what do you think?
Re: painted intercooler or not
I voted black, but that is because I assume that you would go ahead and get the swain tec coating that reduces friction of any surface to another material , causing air to run smoother and faster across fins. According to them it can increase the cooling efficientcy of any thing it is put on. Some coat their intake manifolds with this stuff to increase flow to head. It comes in black.
Plus if it is black, no one will know you have a turbine untill they hear it boosting on past them.
I went black. sometimes i wish i hadnt for the bling factor, but having a sleeper is fun sometimes, and your car gets noticed less.
also the swain tec coating it comes in a can or something?? and where do u buy that stuff, sounds cool, id thought that coating it would reduce cooling effectiveness.
Moderator
The coating Swain tech uses is a type of thermal insulator. This reduces the radiant exogenric heat that occurs with manifolds and turbine housings so that they can be used a bit more efficiently, keep engine temps down, and look good. The application is not like VHT which can be bought in a can.
black painted, black couplers, black clamps, and black piping (only the two pipes going to the IC).
HOWEVER...everyone in my state wants turbos for two reasons...a shiny intercooler, and a blow off valve, so I converted to the light side and stripped the paint when I swapped the motor to my civic to help with the sell...I know, I'm a sell out.
omgwtfbbq made a good point, its important to black out your piping and couplers that can be seen if you want the full stealth effect.
I done both. They both have their pros and cons. Now I'm still debating if I want to block my IC on my setup I'm finishing up.
DO IT ON ALL FOURS
Everyone should know from way back when in Science class that metal that is painted flat black, especially aluminum, dissipates heat faster than a shiny/reflective surface. Go black for function and the sleeper look or polish it because you want everyone to know exactly which car to steal... ***BOO TO THEIVES***
