P8R head... What pistons??
Old 12-30-2010, 09:13 AM
Gunmetal_B20_Hatch's Avatar
Default P8R head... What pistons??
Acquired a P8R head for my turbo non-vtec build. As you may know, P8R utilizes a larger VTEC sized valve than other non-vtec heads. So this poses a problem when ordering forged pistons for my build(due to valve reliefs needing to be larger than normal non-vtec forged pistons). Block is going to be sleeved and bored to 84mm. Do I just get 84mm pistons for a VTEC engine? Will there be any problem putting these pistons on LS Eagle rods?
Thanks H-T!
Old 12-30-2010, 11:15 AM
kyden's Avatar
Default Re: P8R head... What pistons??
all the aftermarket pistons have big enough valve reliefs. its just up to you to pick what compression you want.
Old 12-30-2010, 11:20 AM
Spawne32's Avatar
http://www.jepistons.com/Catalogs/SR.../b20_b16a.aspx
the JE SRP pistons for the B20 with the b16 head are designed for 33mm valves (as the b16 head has 33mm valves), its what im gona be going with
haas480
07-27-2009 10:15 AM
Prototype115
Honda Civic (2006 - 2015)
13
09-29-2007 10:35 AM
xDicktonesx
12-26-2005 05:50 AM
knoj
09-30-2004 07:39 PM
b20ek
05-06-2003 08:25 PM
Quick Reply: P8R head... What pistons??
