p30 oil pan the same as p72 oil pan???
like topic says is the b16 oil pan the same as a b18c oil pan?? need to know due to z10 block girdle install.. it says i need the gsr/r oil pickup and windage tray.. but i need to know if i need the oil pan too.. or if my p30 pan will work fine
Re: p30 oil pan the same as p72 oil pan??? (NJIN BUILDR)
i knew they were different part #'s.. didnt know if they were basically the same.. im just going to pick up the gsr/r windage tray and oil pickup =.. hope the b16 pan works.. if not ill have to source one out then.
Re: (stockb18c)
Reason a B16 pan won't work on a GSR is because of the 3-main girdle. I'm sure you will probably run into the same issue with an aftermarket girdle.
Re: p30 oil pan the same as p72 oil pan??? (ShortbusEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShortbusEK »</TD></TR><TR><TD CLASS="quote">i knew they were different part #'s.. didnt know if they were basically the same.. im just going to pick up the gsr/r windage tray and oil pickup =.. hope the b16 pan works.. if not ill have to source one out then. </TD></TR></TABLE>
The B16 will not work.Like I said above the p72 is deeper.This is to allow the girdle to fit.
ok makes sense now.. the GSR's have a factory girdle.. explains why i need to use GSR main studs.. thanks guys!
The Poopsmith
02-25-2003 11:31 AM
