Oversize Valves
Old 12-15-2004, 05:24 PM
shortyz's Avatar
Default Oversize Valves
are oversize intake valves worth it, some people say "not unless your 600hp" others say yes..
whats the deal.
Old 12-15-2004, 05:28 PM
Trance minister's Avatar
Default Re: Oversize Valves (shortyz)
Shorty'z whats up? I too am curious to know. I've been working on building up a head for FI and just got a set of SS valves in standard size. Wondering how much of a difference larger valves will make and what type of machine work needs to be done to the head in order to fit them.
Old 12-15-2004, 05:34 PM
shortyz's Avatar
Default Re: Oversize Valves (Trance minister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trance minister &raquo;</TD></TR><TR><TD CLASS="quote">Shorty'z whats up? I too am curious to know. I've been working on building up a head for FI and just got a set of SS valves in standard size. Wondering how much of a difference larger valves will make and what type of machine work needs to be done to the head in order to fit them. </TD></TR></TABLE>
sup hmt *****! :D
Old 12-15-2004, 06:47 PM
Bump this up for some wanted info
Old 12-15-2004, 08:08 PM
shortyz's Avatar
earlllllllllllllllll please help us..
B20luda's Avatar
bump it up again cause im in the middle of gettin my head ported and wanting to know if bigger vavles are better also...
Old 12-15-2004, 08:24 PM
snoochtodanooch's Avatar
Default Re: Oversize Valves (B20luda)
as far as i have found, P&P and most headwork, besides maybe cames, will not give a whole lot of gain until your running alot of HP
Old 12-15-2004, 08:35 PM
z6
z6's Avatar
the best head improvement for flow is a valve job, making the air miss the valves better will yield more power than an oversived valve
Old 12-15-2004, 08:44 PM
DRIVENRacing's Avatar
Default Re: (z6)
oversizing valves helps, esp. w/boost... intake valves mostly, exhaust is not necsry.
Old 12-15-2004, 09:24 PM
earl's Avatar
Default Re: (TurboHybridEG6)
In general terms, a .5mm oversized valve is good for about 10 cfm more flow over the stock size when everything else remains equal.
Old 12-16-2004, 09:23 PM
PrettyLude's Avatar
thank you earl
Old 12-17-2004, 07:52 PM
shortyz's Avatar
Default Re: (PrettyLude)
is this 10cfm at idle, or at full throttle?
Modified by shortyz at 9:07 PM 12/17/2004
SirRevvs
10-14-2010 10:32 AM
one-cam
07-06-2008 10:00 AM
hondachris1994
01-19-2007 06:24 PM
95boostedteg
09-19-2005 07:30 PM
mr. wu
13
06-17-2003 08:58 PM
Quick Reply: Oversize Valves
