Oil in intake inlet of turbo. My turbo seals screwed?
Old 11-28-2002, 07:23 AM
BoostedD15B7's Avatar
Default Oil in intake inlet of turbo. My turbo seals screwed?
Yesterday i took my intake filter and pipe off my turbo(t3/t4) and there was oil in the air inlet of the turbo. In by the fins, the oil was really black from being wipped by the fins. Where did it come from? Turbo isnt even a year old. I have an oil catch tank. One of the lines is tapped into the intake pipe. Could this be depositing there from the catch can?
Old 11-28-2002, 08:08 AM
GraphiteAccord's Avatar
Default Re: Oil in intake inlet of turbo. My turbo seals screwed? (BoostedD15B7)
only one way to find out, disconnect the catch can, and clean that pipe out. see if it is still putting oil in that pipe.
Old 11-28-2002, 08:19 AM
AlphaKennyWun's Avatar
Default Re: Oil in intake inlet of turbo. My turbo seals screwed? (GraphiteAccord)
I could help IM me or post here
1st question does it smoke?
Old 11-28-2002, 09:51 AM
Default Re: Oil in intake inlet of turbo. My turbo seals screwed? (SO3Burner)
No smoke i know of....just a little black smoke. But its always done that. It runs rich.
Old 11-28-2002, 10:57 AM
How much oil you talking about?
try this.. get a friend. Have him free rev the car while its standing still in neutral. You stand behind. If it smokes grey/bluish as the motor is revving down back to idle then its da turbo seals.
Old 11-28-2002, 02:53 PM
MiraiZ's Avatar
could be blowby
Old 11-28-2002, 06:13 PM
BoostedH23a1's Avatar
Default Re: Oil in intake inlet of turbo. My turbo seals screwed? (MiraiZ)
no your car doesnt smoke.. he has a built motor. broke in correctly....
Old 11-28-2002, 07:27 PM
Default Re: Oil in intake inlet of turbo. My turbo seals screwed? (BoostedH23a1)
Is it possible that oil particles are being carried airborne and just depositing there. Here is a pic of how the catch tank is hooked up. Notice the hose by the filter. Suction by the intake would draw air from the catch tank.
Old 11-28-2002, 07:46 PM
accorracer's Avatar
what is the pipe comin off your dump tube made of?
Old 11-28-2002, 08:10 PM
juicy.koreans.suck's Avatar
Default Re: Oil in intake inlet of turbo. My turbo seals screwed? (accorracer)
look like high pressure hose from the hardware store held on by a ghetto exhaust clamp (no offense)
Old 11-28-2002, 09:29 PM
Beard
Rguy's Avatar
Default Re: Oil in intake inlet of turbo. My turbo seals screwed? (juicy.koreans.suck)
That oil catch can is not hooked up right at all. Should go from PCV valve to intake manifold. Its not doing anything the way its hooked up now.
Old 11-29-2002, 03:19 PM
Default Re: Oil in intake inlet of turbo. My turbo seals screwed? (Rguy)
hmm thats how i have mine too.. but mines different that civics/integras... no oil leaks yet.. so it works for mine..
Old 11-29-2002, 03:20 PM
oh that is just exhaust flex pipe.. what the hell is so getto about that. its not a zip tie... u cant weld that its to thin. and the muffler shop's welder is named BO so u know he will **** **** up.. damn the south!
Old 11-29-2002, 04:24 PM
i was saying that the clamp was ghetto. he should use a normal clamp. not an exhaust pipe clamp.
Old 11-29-2002, 04:39 PM
filetofit
Guest
Posts: n/a
How's your drain line, I haven't had it happen personally, but I've heard that if you've got a low entry point into the oil pan it'll cause oil to back up and blow out the seals.
Old 11-29-2002, 04:55 PM
Quiklude's Avatar
Default Re: Oil in intake inlet of turbo. My turbo seals screwed? (filetofit)
my return line got pinched and was pushing oil out the seals, but that is all fixed now. just breaking in the built h23 turbo as we speak
Old 11-30-2002, 06:36 AM
Default Re: Oil in intake inlet of turbo. My turbo seals screwed? (Quiklude)
Thats how it says to hook it up on the back of the box. And the pics i saw of the greddy civic on back of import tuner was the same way. The PCV valve on mine doesnt go into the vavle cover. Its on the intanke manifold.
Old 11-30-2002, 06:56 AM
Thats how this website says to do it also.http://www.roadraceengineering.com/i...dycatchcan.htm
Old 12-08-2002, 07:22 AM
get a b18c5 with your kit dogg..
GdmLaz
06-24-2006 08:32 PM
blaze the chemi
05-16-2005 07:21 AM
Gsr_Hybrid_theory
12-24-2004 06:53 PM
extrmeboost
07-29-2003 05:33 PM
guyuenvy
06-27-2001 07:43 AM
Quick Reply: Oil in intake inlet of turbo. My turbo seals screwed?
