Oil on FUEL RAIL? what gives
Ok so latest update to those that have been following me....
Ive got some oil on my fuel rail.......the only source that i can locate is my breather filter on my valve cover. now i think im having some valve issues. could this allow oil to get out and thus evacuate through my breather filter?
Re: Oil on FUEL RAIL? what gives (NYb16)
Have you inspected the breather filter element? For cracks? Valve cover gasket? Oil on top, side or underneath the rail?
Re: Oil on FUEL RAIL? what gives (98Psi ITR)
oil on top side of fuelrail (visable if standing infront of car looking down)
Notes:
JUST replaced stock Valve cover with a CTR Red one.....however the oil drops were there before the switch) its a K&N Filter, i trust its quality
help!
Notes:
help!
well since you are lost compresion, the oil is going past the ring lands and into the breather filter. Its normal when you loose compression.
art
art
Re: Oil on FUEL RAIL? what gives (Arturbo)
however art....
if you have been reading up on my last post (hehehe) you would note:
I did the test under inproper conditions (Cold engine, throttle body closed)
i RE-DID the compression check with a warm engine, and my foot to the floor (open throttle body) and my #s were right where they should be!
so compression is fine i guess! im so confused....but could the oil rings be going anyways?
IloveNewt
01-21-2004 10:13 PM
