***Official F22B Turbo Thread***
#55
Re: (ForceFed_Motorsports)
not yet. just finished the rebuild last week. hooked up the turbo yesterday and we still have some gremlins in the system but after that is all corrected i am going to go to have some ECtune magic done to it.
#57
something different
1 Post
my f22 nonvtec stock bottom end EF (pictured above) just ran an 11.7@ 125 the other night. only got one full boost run in....(PACKED)... should have mid/low 11's in it with a full tune, and the better turbo i'm strapping to it this week..
#60
Here is my boy's accord with a nonvtec f22
simple setup with an evo 16g, dsm manifold, delta cam, etc.
Setup made 270whp on 9psi through a full 2.5" exhaust with an old worn out motor and ran 13.2@104mph
Now it is straight open 3" downpipe and has a few more upgrades with more boost + a new block ( old one suffered from a huge boost spike )
#61
Re: (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">Here is my boy's accord with a nonvtec f22
That's mine! Good old Mshue tuned the monster and the only problem it has at the track now is trraaccttion! Regardless, get ready for some more go-fast upgrades this summer.
#62
Re: (redzcstandardhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redzcstandardhatch »</TD></TR><TR><TD CLASS="quote">my f22 nonvtec stock bottom end EF (pictured above) just ran an 11.7@ 125 the other night. only got one full boost run in....(PACKED)... should have mid/low 11's in it with a full tune, and the better turbo i'm strapping to it this week.. </TD></TR></TABLE>
wow very nice... just curious if you know the weight of the car? cause 125mph traps is FLYING for the amount of boost your running.
#63
Re: (teamlegacy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamlegacy »</TD></TR><TR><TD CLASS="quote">That's mine! Good old Mshue tuned the monster and the only problem it has at the track now is trraaccttion! Regardless, get ready for some more go-fast upgrades this summer.</TD></TR></TABLE>
Heck yea man
Heck yea man
#66
Do you even PLEBE R8?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redzcstandardhatch »</TD></TR><TR><TD CLASS="quote">my car weighs 2020lbs.. 24.5'' x 8'' slicks.
anybody else running an undampened crank pulley? i think its contributing to my oil pumps dying.</TD></TR></TABLE>
Wow thats light, nice work. Ive heard good things about prodrive but for the most part with any high revving motor an upgraded crank pulley should be a must.
#67
something different
1 Post
well, i guess you'd call a tiny undampened crankpulley an upgrade, power wise. its doing what it should, but i think i might need a dampner (ATI, etc), or at least a factory one.
H dampners/pulleys fit F engines right?
with our injector duty cycle, we assume its making about 400 whp. gotta figure out this oil issue though
#68
Damn 2020lbs, my accord is a tank compared to that... just add about 1000 lbs... ... I feel fat.
I would stick with stock oil pump gear but I would definately be using a dampened crank pulley, the problem is where do you find one? No one can tell me for sure if the h22 ones would be ok on the f, so I have been stuck with putting the stock damper/ pulley back on for now.
I would think the h22 damper/ pulley would be ok, very similar motor afterall but.. I dont want to asume what I dont know.
I just know I definately would be running some kind of damper... whether stock or aftermarket.
Modified by twkdCD595 at 12:51 PM 7/12/2007
#69
ATI is a good unit... i would think you should be able to use an H on the F. Only way to know is to try it and then post it up so everyone can be informed
#70
I wonder if bisimoto or someone is running one on his f series... just curious.
Anyone wanna donate a fluidamper to me.
Edit: I am going to run the stock one for now, it is in good condition and maybe switch at a later point.
Modified by twkdCD595 at 12:49 PM 7/12/2007
#71
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed_Motorsports »</TD></TR><TR><TD CLASS="quote">Only way to know is to try it and then post it up so everyone can be informed </TD></TR></TABLE>
I posted that as a rule of thumb... obviously it will work since your using one now, *cough*jackass*couch*
#72
something different
1 Post
bisi is running one of his pullies (like i have), as are MANY other guys...it seems to work great in lower HP or limited use applications. i dont doubt it'd be fine on a stock engine...
mines making an estimated 390-410 whp, and similar torque numbers though.
talking to ATI about getting drawings for a damper, to see if it'll fit in my swap..might have to knock away the frame more
#73
Oh right i didnt even think about it interfering with the frame... hope the belt doesnt go bad lol. Might be loosening some motor mounts to get it off.
#75
something different
1 Post
Re: (Mr Wonderfull)
yeah...they put HUGE MF'ers on these things from the factory..
anybody think a modified B series pulley would dampen enough (factory pulley, with the hole opened up enough)
