The Official Crankcase Evacuation thread for Turbo Hondas / PCV / Catchcan /
Old 07-24-2005, 05:32 PM
  #251
turbotypeR@SPEC's Avatar
Default Re: The Official Crankcase Evacuation thread for Turbo Hondas / PCV / Catchcan / (dasher)
bump
Old 07-25-2005, 08:17 PM
  #252
b16hybridsol's Avatar
Default Re: (The Jacko)
up
Old 07-25-2005, 09:14 PM
  #253
dasher's Avatar
Default Re: (b16hybridsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">Theres a problem with trying to draw the pressure out of the valvecover through 2 drilled holes on the front of an h22a. The h22a doesn't have baffleing in the front like b-series, and there really isn't much room up front to even make a baffle. From the way i understand it, the exhaust side is where most of this excess pressure is generated, so what can be done aside from a new valve cover?</TD></TR></TABLE>
Weld in a 90 degree port which turns slightly upward.
Old 07-25-2005, 09:40 PM
  #254
Default Re: (dasher)
i think i'm going to weld in my own baffle, and place the 2 -10an vents right in front of a cam bearing cap just to be safe on the oil slinging from the cams
Old 07-26-2005, 03:20 PM
  #255
Just Another Civic's Avatar
Default Re:
I have read this a few times and believe I have this correct. I just want to run it past you to make sure...
Thanks in advance for the yes or no go on the setup.
Old 07-27-2005, 12:01 PM
  #256
Default Re: Re: (Just Another Civic)
Bump for a reply. Car is ripped apart right now and waiting for an answer til it goes back together.
Old 07-27-2005, 12:34 PM
  #257
Keith P's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Just Another Civic &raquo;</TD></TR><TR><TD CLASS="quote">Bump for a reply. Car is ripped apart right now and waiting for an answer til it goes back together. </TD></TR></TABLE>
The return should be from the bottom of the catch can. And don't forget to plug the hole in the intake manifold.
Old 07-27-2005, 02:46 PM
  #258
Ef88Lsvtec's Avatar
Nice
Old 07-28-2005, 01:09 PM
  #259
Default Re: Re: (Keith P)
I realize this may be an old post to many but its very new to me. I have redone my drawing and am almost positive this is the correct setup after reading the [I]entire[I] thread yet one more time.
As far as the return being at the bottom of the catch can: wouldn't that defeat the entire purpose of trying to "catch" the oil/contaminets and just drain it back in...
Anyways here is the plan in motion for my setup, please advise if something is *** backwards.
Like I said I'm pretty confident on this now but after reading this post like 5 times I have a really bad headache and would just like to make sure all is well
Old 07-28-2005, 06:43 PM
  #260
boostedDA's Avatar
Quick question, see if this is okay.
Remove black box.
Plug the hole where the black box was.
Remove the hex bolts and install new Honda fittings.
Run hose from the two fitting and point it at the ground.
Put breather on valve cover.
Run wastegate line to the open nipple on intake manifold.
I'm just trying to figure out how to eliminate the use of a catchcan.
Old 07-29-2005, 08:58 AM
  #261
epic1si's Avatar
i got a question about blocking off the breather box. i called endyn and asked if they sold the plug seperately and they told me they get them from orielly dorman # 555-104. but they are steel. so is it a bad idea to use that part or should i just go ahead and order the aluminum one from z10?
Old 07-30-2005, 11:46 AM
  #262
boostedDA's Avatar
bump
Old 08-01-2005, 04:09 AM
  #263
Keith P's Avatar
Default Re: (epic1si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by epic1si &raquo;</TD></TR><TR><TD CLASS="quote">i got a question about blocking off the breather box. i called endyn and asked if they sold the plug seperately and they told me they get them from orielly dorman # 555-104. but they are steel. so is it a bad idea to use that part or should i just go ahead and order the aluminum one from z10?</TD></TR></TABLE>
Most REAL autoparts stores have freeze plugs. The ones I got locally were zinc plated steel.
Be sure to use hondabond!
Old 08-02-2005, 09:21 PM
  #264
Default Re: (Keith P)
When using the slashcut exhaust method and using a sealed catchcan off the block, does (1) the catchcan need to be baffled? and (2) does the placement of it in the engine bay matter (when using a vented catchcan its gotta be as high up as possible-does this apply to the unvented or can it be placed wherever)?
Old 08-09-2005, 01:05 AM
  #265
Default Re: (Just Another Civic)
bump
Old 08-24-2005, 01:47 PM
  #266
Si Integra's Avatar
Default Re: (xaznxboixgsrx)
Would I benefit at from doing this:
Run a line from the former pcv spot on valve cover to a nipple on the catch can. Run the other line from the nipple on the catch can to the breather box on back of block. Then run a line from the ventilation nipple on the valve cover into a slash cut tube on the waste gate.
My car is really lacking space and everything is super tight under the hood. I am looking for the easiest way to offer some ventilation w/o contaminating my intake charge and turbo. I also do not want to run the slash cut tube into my downpipe.
I have a sealed catch can and the valve cover from a 99 Integra LS, so the pcv is in the valve cover.
W/O welding nipples on the front of the valve cover and w/o using the freeze plugs to replace the oem box, what are my options?
Sorry is some of this sounds like it does nto make sense, i am a tad jumbled from reading so many pages of info and all after working all day.
Thanks in advance for any help!
Old 09-02-2005, 06:59 AM
  #267
Mr. Vapor's Avatar
Default Re: (Si Integra)
subscribing...
Old 09-02-2005, 08:40 AM
  #268
Default Re: (Mr. Vapor)
bump
Old 09-02-2005, 09:05 AM
  #269
RACEPAK's Avatar
Old 09-02-2005, 09:31 AM
  #270
flood's Avatar
That is one hell of a writeup. Thanks
Old 09-05-2005, 03:46 PM
  #271
Default Re: The Official Crankcase Evacuation thread for Turbo Hondas / PCV / Catchcan / (flood)
anybody have the instructions for the endyn kit online?
Old 09-05-2005, 03:51 PM
  #272
BlueShadow's Avatar
Default Re: The Official Crankcase Evacuation thread for Turbo Hondas / PCV / Catchcan / (turbotypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR &raquo;</TD></TR><TR><TD CLASS="quote">anybody have the instructions for the endyn kit online?</TD></TR></TABLE>
I think it's somewhere between page 1 through 9 of this thread.
Old 09-05-2005, 06:23 PM
  #273
Ef88Lsvtec's Avatar
Nice Writeup
Old 09-06-2005, 12:24 AM
  #274
crazy_eddy's Avatar
bump for great info
Old 09-08-2005, 08:24 AM
  #275
Default Re: (crazy_eddy)
I'm curious to know if anyone else with the downpipe slashcut method is noticing excessive smoking only when idling after the car has been warmed up. I know its gonna smoke and I could care less, but I thought that the smoking would be during WOT not during idling.
Quick Reply: The Official Crankcase Evacuation thread for Turbo Hondas / PCV / Catchcan /
