non vtec sohc TURBO camshaft?
I have searched the forum already and found nothing. Are there any good camshafts available for a non vtec sohc? its for my sandrail, so as long as it will stay running, I don't care much about idle. Head will be ported, and I will build a custom intake manifold for it, so she will have no problems breathing as long as it gets a decent cam.
Bisimoto.com look at the web site and then call and talk to Bisi tell him what you are looking for, he should have an off the shelf grind that will work for you,or can have one ground special to your application. He has several "levels" of turbo grinds. He's pretty much the single cam guru and a really good guy.I have a mildly built A6 and am going to use the level 1.2 since its going in a daily driver. Look at the level 2.4 it might work for you.
Stu22
28
02-04-2006 09:10 AM
