NGK BCPR7ES-11 Spark Plug Gap?
I did some searching on here and I did not come up with the correct gap for these ngk BCPR7ES-11 plugs that I am using on my d16z6 with a jrsc. I called jackson racing and they told me they were pregapped. Upon checking the gap on them, they are all between .39-.41 What exactly are these supposed to be gapped at? If they all were gapped the same, I wouldnt worry about it. Being told they are all pregapped and they are all a little different, I want to make sure exactly what I need to gap these at.
Thanks in advance.
Thanks in advance.
Re: NGK BCPR7ES-11 Spark Plug Gap? (ShowTymers619)
dude it isn't .41.... it should be "0.041"
.41 is nearly almost one half of an inch....... |<-->| <------now that is about the distance you are mentioning......
not being a d1ck just letting you know bro....
high boost go .025-.030 .... lower boost level 5-10psi you are good at .035-.040
Re: NGK BCPR7ES-11 Spark Plug Gap? (nicholashang87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicholashang87 »</TD></TR><TR><TD CLASS="quote">dude it isn't .41.... it should be "0.041"
haha, sadly enough I realized that this morning after looking at it. Thanks for pointing it out. lol.
so I think I will put them somewhere between .0035 and .0040. Thanks for the advice.
ok, pu tthe decimal in the wrong place.
yes I know they were supposed to come pregapped, but when they all were either 0.039 - 0.041 they are not gapped right for my application. Thats more than 1.1mm.
