New Dizzy, New coil, No F-N Spark !
Old 12-16-2007, 11:12 AM
NeKe1point0's Avatar
Default New Dizzy, New coil, No F-N Spark !
1994 Accord
F22b2 t3/t04e .63 AR
I recently removed the head,went to re-start and the motor is turning over but just wont fire up. so i start diagnosing what the hell it could be. thinking i have over looked a ground instantly. i check the helms and checked all the ground locations. the intake mani,valve cover and battery. i checked the engine harness to make sure all sensors were plugged in and everything is in its spot. i checked and re checked timing. looked at all the fuses, everything looked good. pulled plugs and they are covered in fuel, and the motor is compressing, just no spark !!!
i tried to force spark to jump with the car on and turn the motor over manually. nothing. read a **** load of post that said normally if the dizzy goes the coil will too (both were original with 150k on them) so i bought a new dizzy and coil. the dizzy is from dist. king and the coil is from honda. plugged them all in and even took the cap off the dizzy to verfy it was at the num one pos. but still no spark !!! this is !!!!!!!!!!! also, im not throwing any CEL codes this is driving me crazy !!! someones got to know what im overlooking ! i can post vids or pics if needed. thanks in advance guys
Old 12-16-2007, 11:44 AM
Turbo-charged's Avatar
Default Re: New Dizzy, New coil, No F-N Spark ! (NeKe1point0)
its been a while since ive worked on an accord, but there is generally a group of grounds all on one ring terminal that is in the general location of the thermostat housing. with out that ground hooked up, you wont get spark. something easy and free to check lol
Old 12-16-2007, 11:51 AM
Default Re: New Dizzy, New coil, No F-N Spark ! (Turbo-charged)
ok ill check there again, but i thought that was the one on the intake mani. it has a few wiresbutted into one fitting. thanks for the help
Old 12-16-2007, 11:55 AM
ok yea maybe thats where it is on the accords.
Old 12-16-2007, 02:05 PM
prob solved - back to boostin !!!!
Old 12-16-2007, 02:10 PM
OLD_HATCH's Avatar
What was the problem?
egcoupe918
48
12-20-2012 02:16 PM
hey man
12-22-2010 06:59 AM
NeKe1point0
01-21-2008 06:07 PM
crxzc
06-09-2002 06:50 PM
Quick Reply: New Dizzy, New coil, No F-N Spark !
