need opinions on oil drain route - Honda-Tech
Old 03-20-2017, 05:10 PM   #1
cityofcaterpillars's Avatar
Default need opinions on oil drain route
So I'm mocking up my turbo and ran into a small problem. I got a drain kit from fast turbo and I don't know if it's going to work. It's super short. I have the original fitting for the turbo and rubber hose I was going to use before I ordered the fast turbo kit. I could really use some advice on which route to go.
Fast turbo fitting
original fitting
option 2 with rubber hose
option 3 using AN fitting on oil pan
cityofcaterpillars is offline   Reply With Quote
Old 03-20-2017, 06:32 PM   #2
93h2beg's Avatar
Default Re: need opinions on oil drain route
what size hose?
93h2beg is offline   Reply With Quote
Old 03-20-2017, 06:42 PM   #3
the braided? I have no idea. It goes on a -10 AN fitting if that helps
Old 03-21-2017, 05:51 AM   #4
LightningTeg's Avatar
#3. KISS
LightningTeg is offline   Reply With Quote
Old 03-21-2017, 08:14 AM   #5
Moderator
TheShodan's Avatar
Use the rubber hose using a steel barbed fitting that can be welded to the pan. I use those on low-sitting "Mini-ram" manifolds using GT series all the time.
TheShodan is offline   Reply With Quote
Old 03-21-2017, 01:14 PM   #6
Rubber hose it is then. I never expected the fittings to be that close together. thank god for mock ups
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
