Napa part# for dsm injector Seals& orings?
I got the dsm 450 and will be usiong them with a b18c JRSC set up there was a link showing the napa part # and how to install them but i lost it does any one have it?
Re: Napa part# for dsm injector Seals& orings? (legutki)
just get some o-rings that fit on your stock injectors. I used my stock injector o rings for my 450's and it worked perfectly fine
Re: Napa part# for dsm injector Seals& orings? (Vtec92Civic)
Re: Napa part# for dsm injector Seals& orings? (twkdCD595)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 »</TD></TR><TR><TD CLASS="quote">http://www.homemadeturbo.com/t....html
2-12089 per the pics I see.</TD></TR></TABLE>
Thats the link thanks
That's the part # for the civic...not DSM. I've been searching for that green insulator forever. My local Napa doesn't list a lower insulator, nor does their website. If somebody's got it, please pm me with the #.
you cant find that **** anywhere!
unless you get super lucky and have little "import" only parts store.
napa, autozone, murrys, and advanced auto parts DO NOT carry any type of o-rings for injectors. You really have to order them from honda.
your DSM injectors will use the exact same o-rings as honda ones. you have to buy the whole gasket set from honda which is like 6-7$.
i speak from personal experance
Re: Napa part# for dsm injector Seals& orings? (LEGUTKI)
I have a JRSC and DSM's in my Si. I just doubled up the stock injector seals, which is an even better fit. Oh, don't bore out the seals while they are in the manifold. Use the finer sanding drum and hold it with your hand and be careful. It does a little better job achieving a better fit.
Re: Napa part# for dsm injector Seals& orings? (oscarmayer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oscarmayer »</TD></TR><TR><TD CLASS="quote">mitsu dealer?? have you tried there? can't be that expensive for 4 o-rings...</TD></TR></TABLE>
OEM Honda injector seals are $7/ea.!
Re: Napa part# for dsm injector Seals& orings? (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX »</TD></TR><TR><TD CLASS="quote">OEM Honda injector seals are $7/ea.!</TD></TR></TABLE>
Apparently Mitsubishi parts are cheaper than Honda parts.
Go to http://www.partznet.com , give Conicelli a call and get 25% off list price.
If you guys are just looking for o-rings, then go to Autozone and buy the o-ring packs in the Help! section. Mitsubish wants $2-3 for (1) o-ring (ask me how I know!)
My local NAPA had those seal kits, and those green manifold seals are nice and thick; good stuff! The stock ones are very flimsy.
