My Turbo List , give me ur advices
Old 02-12-2014, 01:42 PM
winner-civic's Avatar
Default My Turbo List , give me ur advices
Hi every body ..
This is my first Turbo list , how much hp expected in Octan 95 and in C16 ? what is maximum hp can I use it in street ? can I have more than 750 hp if I want drag in the future by increase size of injectors + change clutch + CNC sleevs ?
My Turbo list on 2000 Coupe Honda civic :
B18B Ls Block
B16A Vtec Head
Y80 Integra Gear with turbo street ratio 4:2
Hasport Workamount
CP 9:0 compression Piston
MANELY H-beam Connect Rod
ACL Bearing Kit
ARP Main Studs
Golden Eagle Ls/Vtec Head gasket
Skunk 2 Pro 1 Cams
Supertech Double Spring & Retiners
Ferrera Valves Kit
ARP Head Studs
Edelbrock Victor X Intake Manifold
Blox 70 mm Throttle Body
ATI Crank Pulley
Blox Cams Pulley
Belt
AEM Fuel Line
AEM Fuel Rail
Fuel Regulator
Oil Catch Can
Dynamics 1000 CC Injectors
Aeromative Fuel Pump
Spec Single Plate Stage 3+ Clutch
AEM V2 ECU
3.0 Bar Map Sensor
Solanaid
PRMS Ramhorn Headers T3 with A/C
Precision 6266 Ball Bearing T3 with A/R 0.82
Precision 46 mm Westgate
Copy Tial Blow Valve
Cope Intercooler
Custom Pipes and Turbo Exhaust
AEM ( Boost + Oil Pressure + Waidband ) Gauges
Teen Suspension
Old 02-12-2014, 03:28 PM
Tegger93's Avatar
Default Re: My Turbo List , give me ur advices
Looks like a good start, you might need some upgraded axles if you're serious about 750hp.
hondaman177
03-25-2018 01:34 PM
Jjmartin1992
06-15-2013 11:48 AM
joepiscapo_83
12-01-2004 08:17 AM
b18bturbosoon
02-21-2004 09:51 AM
Quick Reply: My Turbo List , give me ur advices
