my car revs up and down alll day..
Old 01-23-2006, 09:19 PM
egturbo1's Avatar
Default my car revs up and down alll day..
well its a b18b turbo in an eg.. it revs up and downallll day.. replaced teh iacv still reving up and down.. what else can it be? not a vacuum leak. thanks.
Old 01-23-2006, 09:38 PM
exotik4doorcivic's Avatar
Default Re: my car revs up and down alll day.. (egturbo1)
i had this problem in my car for over a year it can be anything from
low coolant
map sensor
blown head gasket
iacv
fast idle valve
try unplugging the tps sensor and adjusting the idler screw
or the screw under the throttle body that will also adjust the idle
Old 01-23-2006, 09:48 PM
earl's Avatar
look for a vacuum leak...maybe a vac hose with a leak?
Old 01-23-2006, 09:54 PM
88_DX's Avatar
Default Re: my car revs up and down alll day.. (earl)
Try the FIT valve
Old 01-23-2006, 09:59 PM
uglyasscivic's Avatar
Default Re: my car revs up and down alll day.. (88_DX)
Take off the upper IC pipe and cover up one of the two hole inside the throttle body and see if the surging stops. If it does then it is the fast Idle valve.
Old 01-23-2006, 10:21 PM
Synapse's Avatar
Default Re: my car revs up and down alll day.. (uglyasscivic)
It could also be your TPS. Check engine light?
Old 01-23-2006, 10:41 PM
underb00steg6's Avatar
Default Re: my car revs up and down alll day.. (Synapse)
if its not a vacuum leak , have you checked the tps? ......or the iacv?
Old 01-23-2006, 10:44 PM
egturbo1's Avatar
nope no check engine light
whats weird is that i had this problem before.. and then it went away completely
then after i put in seafoam it came back and never went away..
changed teh iacv yesterday still happening
umm messed w/ the thing under teh t/b oopen the two screws put it back ntohing..
was low on coolant. but taking out the intake pipe.. i'd have to do soomuch work what else can it be?
Old 01-23-2006, 11:16 PM
did you unplug the tps plug and adjust the idle?
also when you are changing sensors make sure to reset the ecu
whats sea foam?
Old 01-24-2006, 06:41 PM
egturbo1's Avatar
Default Re: my car revs up and down alll day.. (exotik4doorcivic)
sea foam is something to clean out ur internals. i dunno made my car worst if u ask me
Old 01-25-2006, 03:44 PM
sockvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exotik4doorcivic &raquo;</TD></TR><TR><TD CLASS="quote">
whats sea foam?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1016891
https://honda-tech.com/zerothread?id=1059690
Old 01-25-2006, 05:52 PM
slow poke's Avatar
Did it do this before you went turbo?
Its pretty much got to be a vacuum leak dude. It almost ALWAYS is.
Old 01-25-2006, 05:55 PM
ludesleep's Avatar
Default Re: my car revs up and down alll day.. (slow poke)
look under your intake manifold there are a bunch of plastic nipples for vacum that always break off
Old 01-26-2006, 10:56 PM
egturbo1's Avatar
nope was alraedy turbo'd ill try to find it soon gets annoying after some time
Old 01-26-2006, 11:58 PM
lucidvtec's Avatar
i bet it's a vacuum leak....if not use a voltmeter to check ur TPS sensor...i don't think it would be ur map did you change any ECU stuff lately.....what EMS u runnin???
Old 01-28-2006, 03:27 AM
s13browe's Avatar
After using seafoam you should reset your computer cuz it gets tricked into thinking its running rich and takes a while to relearn, also i have heard of seafoam ruining o2 sensors and have had a bad o2 make my n\a gsr motor rev like that till I changed it. FYI: to reset computer remove 7.5 backup fuse in engine compartment for 10 sec or neg battery terminal
Old 01-28-2006, 05:42 AM
sc4dr's Avatar
Take off the pipe going into your throttle body after its <U>warmed up</U>, put your finger over the hole inside on the bottom of the tb. If it's pulling suction then your fast idle thermo valve is bad.
Old 01-28-2006, 06:02 AM
vaporboy12's Avatar
Default Re: my car revs up and down alll day.. (sc4dr)
might alos be air pockets in your coolant
Old 01-28-2006, 07:28 AM
hatch_attack's Avatar
Default Re: my car revs up and down alll day.. (vaporboy12)
throttle body gasket? mine did the same thing. spray carb cleaner around it..if it wants to die out then thats it..
Old 01-28-2006, 07:48 AM
slodc2's Avatar
mine also did the same thing when i blew out my throttle body gasket
Old 01-28-2006, 09:28 AM
SL0WEGG's Avatar
Default Re: (slodc2)
mine also had this problem recently, i knew what it was never really fixed it. well till sunday. it was the FIT, but there are soo many different things that would make it do it. if no vac leaks. can only be the TB gasket or the FIT
Old 01-28-2006, 09:47 AM
f1 vtec's Avatar
Default Re: (boostedej1)
TPS calibration.
Old 01-28-2006, 11:04 AM
sockvtec's Avatar
Default Re: (f1 vtec)
geeeeez my car has been revving up at down from 1k to 3k when its sposed to be idling and theres tons of crap i have to check
oh well...i love working on my car
Excusetoboost
09-01-2011 07:40 PM
I Like Hondas
06-11-2006 05:35 PM
Fatty_1775
08-11-2002 07:28 AM
ITR1071
05-26-2002 11:37 AM
1hottEG6
05-04-2002 11:54 AM
Quick Reply: my car revs up and down alll day..
