My B18C1 Engine Build/Assembly
#4427
No-Traction = Fun
Re: My B18C1 Engine Build/Assembly
well seems a tiny bit better until I hit vtec. Cams are degree perfect. So I'm going to try some less aggressive cams I think.
#4430
Real tuner anyone ???? The issue needs diagnosing properly by an experienced tuner who has the car in front of him
#4431
No-Traction = Fun
Just the fact that the car is saying it need less fuel all across the board is just strait weird. My stock GSR cams were asking for more fuel, even when in vtec than these GSC's were. I'm wondering if there is an issue with my head. I had to have the head milled all the way down to the wear bars on this last rebuild to get rid of the damage in the head on cyl#3. Like I lost my quench value in the head or something.
#4433
DO IT ON ALL FOURS
Do you have OEM cams to put in just to verify? I still think you should bring it to a competent tuner and try to sort things out - but I also understand not wanting to spend the extra money to find out it is still the cams. Double edge sword really... at this point to be cost effective and for a further learning experience it may be best to try a camshaft swap first.
#4434
Damn, doesn't help my situation any further. I'm going to go ahead and have the car tuned on the GSC cams, see what the results are, if it's not good I'll swap in ITR cams and retune, as I know the ITR cams are good for the power level I'm after and have good economy too when not leaning on it. I'm running a ramhorn mani and my bottleneck now is the exhaust housing on the GT3076r (.63)
#4436
No-Traction = Fun
https://honda-tech.com/forums/performance-45/%2A%2A%2A%2A-edelbrock-4730-street-strip-camshafts-clearance-b16-b18c-%24319-set-shipped-%2A%2A%2A-3060430/
#4437
It's not that people are hating on them. People are just trying to come to grip with their true nature/application. Sometimes it's just a simple game of trial and error to get that needed understanding. I'm sure if we were a few years down the line from now he wouldn't be in this situation as all this would of passed.
I'm for him trying the GSR cams just to see how the engine responds. If it responds well then he's going to need to have the GSC's dialed in on the dyno for best results (keep those P2V numbers safe Dave).
#4438
Yes I do need a set of OEM GSR camshafts, I do have a brand new set of Edelbrock 4730 Street/Strip camshafts that are a lot less aggressive. I'm wondering if I should install those and degree them and see what happens.
https://honda-tech.com/forums/showthread.php?t=3060430
#4439
Who are you to make any type of call on how good a cam profile is that you have never even had a car they would fit into? I live all of the ******* implied knowledge that gets thrown around on this board by folks who have never had any actual experience in the matters at hand.
#4440
We do not hate GSC cams, it just might be that there is a problem with these cams or the head and only a cam swap would quickly confirm where the problem could be.
This has been my position for a long time. To me it feels as if you are trying to save the GSC name.
#4441
Having the head milled wont create something like this, it will still flow the same amount of air. I still think there is more to it then the cams. They don't agree with the rest of the "system"
#4442
You don't have to feel bad about these cams, calidad should.
Dave's head was milled a whole.. whole lot.. and it might be a manifold problem.. I would have thought by now and this would have been taking to a real tuner, and got really tuned.. if the problem still persisted, then hey, maybe the cams weren't for you? Not all the time are profiles that are proven, and work, going to work ALL the time, we all know this.
Its sad to see it come to this, this car has alot of work put into it, hopefully trying something else yields better results.. good luck
#4445
I like calidad's build, and hes done a fantastic job putting it together, but taking the GSC cams out and going back to stockers to try to prove a point is a terrible excuse for not going to a competent tuner to get a real in depth diagnosis, especially when soooooo many people are here trying to help with this situation. It is sad to see that even after direct involvement from the cam manufacturer (which you wont find from alot of other companies) and we are still placing the blame on the cams, and not the other shortcomings of this build. Like the tiny little manifold, the terrible tuner that got a hold of the car the first time around, etc etc... This car should have been over at whitfield getting a real diagnosis 3 weeks ago.
#4446
#4447
DO IT ON ALL FOURS
There is an old saying for this - "Impress one person and he will tell another; dissatisfy one person and he will tell a dozen."
#4449
Yes of course it will, but the timing has now been addressed so how does that have anything to do with it. Any amount of head milling can be corrected by degreeing cams (done) and setting base ignition timing which I hope and would expect was done prior to or during the tune attempt.
#4450
