Walbro 450 or Walbro 450 High Pressure?
Old 04-25-2021, 02:10 PM
Stopsign32v's Avatar
Default Walbro 450 or Walbro 450 High Pressure?
I'm not sure which one would be beneficial for a E85 setup with Grams 1000cc injectors. Around 500whp goal
Normal https://walbrofuelpumps.com/450lph-w...0267.html.html
High pressure https://walbrofuelpumps.com/walbro-4...tive.html.html
What is the benefit of going with the high pressure? I read the differences but I cannot put that information into anything I can understand.
Old 04-26-2021, 12:37 PM
DaX
DaX's Avatar
Default Re: Walbro 450 or Walbro 450 High Pressure?
How much boost are you planning to run to reach your goal, and what base fuel pressure? The regular one (which I am using, btw) is only rated to 87 psi fuel pressure before the flow starts to drastically drop off - look at the graph on the link you posted. If you're running 4 bar (58 psi) fuel pressure, you can run 29 psi of boost before you start getting into dangerous territory with the regular pump (58+29 = 87).
Old 04-26-2021, 12:52 PM
I think max psi from a GT3076R is around 25-29psi from what I've read
Old 04-26-2021, 09:19 PM
piggy96's Avatar
My guess would be the high pressure version would be for returnless fuel systems that don’t use a map referenced fuel pressure regulator.
or like Dax said high base pressure combined with high boost pressure
Old 04-27-2021, 08:00 AM
LightningTeg's Avatar
I ran mine @ 55 psi base with 30 psi+ on top to make 650 with E85
Old 04-27-2021, 12:56 PM
DaX
DaX's Avatar
Yeah, I'm at 50 psi base + 29 psi boost, and it hasn't shown any signs of leaning out.
Old 04-27-2021, 08:57 PM
highschooler's Avatar
Might as well get the higher high pressure fuel pump. I think you’d be more safe with it. I used to have a Vortec fuel pressure riser (10:1) FMU using 8psi of boost and didn’t have any problems with fuel on stock injectors and a stock FPR, so I’m guessing I was at 100 something PSI of fuel pressure. The Walbro 255l/hr high pressure fuel pump kept up well. When I went into boost, the fuel pump got louder and had a whine to it.
You might get close to maxing out your 1000cc injectors for 500whp though. If you haven’t purchased them yet, you might want to go bigger, like 1200cc or larger.
clemsonteg
01-18-2006 08:31 PM
MtnCRX
05-07-2005 01:52 PM
djnikko
11-17-2004 03:24 AM
turboH22Aakkord
06-24-2004 11:28 AM
Quick Reply: Walbro 450 or Walbro 450 High Pressure?
