LST / LS-T Turbo B18A B18B setups - Honda-Tech
Old 07-29-2005, 08:47 AM   #1
Munkyw3rkz.webs.com
S@nt0s's Avatar
Default LST / LS-T Turbo B18B's...
Well i have noticed that a lot more guys are out there boosting LS's and i thought it would be nice to have a trend to post set up's and idea/tips for US LS peeps...
so ill start...
stock LS from TB to oil pan
2.5charge piping
FMIC
walbro 255 intank
XS RFL bov
Tial 40mm
BMC log, dump tube and 3" DP
t3t4 60trim .63 a/r turbonetics
RC 440's
Hondata S200
10PSI
250whp 225ft lbs
8.6@84.8mph in the 1/8th on federal tires.... 2.0 60ft....
that was open DP with no extra BS weight STOCK clutch....slippin
New set up
85mm LS block
RS sleeves
Eagle rods
CP pistons 9:5 comp
62-1 stage 5 wheel 63 trim Turbonetics
8.3@86mph on 3 cyliners with my tool box and all my work stuff with the EXHAUST (2.3") hooked up
Modified by Snoflake at 9:42 AM 10/15/2005
S@nt0s is offline   Reply With Quote
Old 07-29-2005, 08:54 AM   #2
DragSource's Avatar
The best advice for an LS'er is:
Head work - if you ever want a useable powerband with a beefy sized turbo, head work is your best friend. Porting, cams, springs/retainers - the works. It's expensive but makes all the difference.
DragSource is offline   Reply With Quote
Old 07-29-2005, 09:06 AM   #3
DurboDug93's Avatar
Default Re: (DragSource)
Heres my setup:
Bone stock ls 104,000 miles
SFP mainfold
Tial 38mm wastegate
Garrett T3/T4 57trim .63ar exhaust
2.5 in open downpipe
2" pipe off of the turbo, 2.25" to the TB
Spearco intercooler
Sard R2D2 BOV
Fast turbo oil lines
Walbro 255 fuel pump
RC 550cc injectors
Hondata S200B
Greddy profec B spec II
Excedy 3 puck clutch
Tuning was done at 10psi. See sig for dyno graph
Dont have any track times yet
DurboDug93 is offline   Reply With Quote
Old 07-29-2005, 09:12 AM   #4
Munkyw3rkz.webs.com
S@nt0s's Avatar
Default Re: (DurboDug93)
DurboDug93,
time it yet????
#'s similar to mine.....
Old 07-29-2005, 09:48 AM   #5
blackeg's Avatar
Default Re: (Snoflake)
ok heres what i got
97b18b, carfax'd at over 200k miles
lovefab shorty
t3/t4 57 trim .63 exhaust
tial 38mm
home made 3" dp/2.5" testpipe and greddy evo catback
drag kit intercooler
2" pipes from turbo to i/c, 2.25" from i/c to throttle body
greddy type s bov
b16 intake manifold gangstered to fit the ls head
stealthmode oil kit
walbro 255 intank
tunertoys 550's
uberdata
hallman mbc
gsr tranny
act heavy duty pp and 6 puck unsprung disc with stock flywheel
i think thats just about it.
my dyno #'s are in my sig, and ill hopefully get track times next weekend
blackeg is online now   Reply With Quote
Old 07-29-2005, 10:05 AM   #6
Thurman Merman's Avatar
Default Re: (blackeg)
****... these are all pretty consistant #'s being put down... very nice fellas
bout a week or 2 ill have some dyno numbers at 10psi, maybe more i'm just skeptical about 165k miles on my motor.... although the guy up ^^ had 200k so
Thurman Merman is offline   Reply With Quote
Old 07-29-2005, 10:09 AM   #7
Munkyw3rkz.webs.com
S@nt0s's Avatar
Default Re: (Thurman_Merman)
my RS has 243K on it but the motor was swaped out for a 97B18B with 80K on it i think im around 95K tho...just doa comp test/leakdown see how the motor is
mine was at less then 4% all the way across the board....
might turn the boost up some inthe futre since i see so many 14-16psi stock LS's
Old 07-29-2005, 10:16 AM   #8
non-VTEC's Avatar
Default Re: LST / LS-T Turbo B18B's... (Snoflake)
any non-VTEC guys with a 2.0L bottom end looking for some serious power i have a serious non-VTEC cylinder head package for sale...click the link in my sig....
nice numbers guys..........
non-VTEC is offline   Reply With Quote
Old 07-29-2005, 10:18 AM   #9
Munkyw3rkz.webs.com
S@nt0s's Avatar
Default Re: LST / LS-T Turbo B18B's... (non-VTEC)
yea ME>..jsut need pistons for my 85mm block...thinking of running 10:1 comp
Old 07-29-2005, 10:29 AM   #10
DAMN!! lol my RS doesnt have that many, just original 165k on motor/chassis.
ill turn up the boost to 10psi next weekend and throw it on the dyno when it's cooler out..... god i hate driving in the hot weather, such a pig
Old 07-29-2005, 10:33 AM   #11
Munkyw3rkz.webs.com
S@nt0s's Avatar
hey shyt happens...LOL
build it, drive it, blow it, **** it!
Old 07-29-2005, 10:36 AM   #12
blackeg's Avatar
my compression is 188-190 across all 4 and my catchcan stays pretty dry. my motor does burn a little oil, but for some reason its much less now after i put the turbo on
Old 07-29-2005, 10:45 AM   #13
Munkyw3rkz.webs.com
S@nt0s's Avatar
Quote:
is that witth 5 or 10 turns of the starter?
mine was 255 with 10 turns and 190 with 5 turns
Old 07-29-2005, 10:45 AM   #14
Is that 200k carfax on the car itself, or is it a different motor?
LOL and how does one go about gangsta fitting the b16 IM onto there ls
Old 07-29-2005, 10:48 AM   #15
Munkyw3rkz.webs.com
S@nt0s's Avatar
Hackinthe flange off and welding a LS one on the mani...hehehe
Old 07-29-2005, 11:11 AM   #16
Junglesnake's Avatar
I put down 240/207 at about 10 - 11 psi on a stock LS with a 57 trim T3TO4E. My best time was a 12.9 @ 111 on 14" street tires with a 2.1 60'.
Junglesnake is offline   Reply With Quote
Old 07-29-2005, 11:16 AM   #17
Munkyw3rkz.webs.com
S@nt0s's Avatar
Default Re: (Junglesnake)
Quote:
nice times what chassis???
Old 07-29-2005, 11:16 AM   #18
lol cacky smart ***.... ill give it a try this weekend, hopefully my tube of jbweld will do the trick
Old 07-29-2005, 11:18 AM   #19
Munkyw3rkz.webs.com
S@nt0s's Avatar
AutoZone is your friend....
back on track...
what Mani's is everyone running?????? i know JG makes the BIG DICK mani for LS's and Blox/skunk2 have one for LS who else????
Old 07-29-2005, 11:28 AM   #20
blackeg's Avatar
prostreetonline is having a sale on blox's. 150 shipped new. i would totally buy one, but ive got some tickets to pay for .
the carfax is on that motor. (my car is a 97 hx with about 10k more miles than the ls i put in it). something is up though, the head is spotless on the inside, so its prolly been hot tanked. when i had the oil pan off, it was dirty as hell, so im assuming the block has never been touched. it is possible my valve seals were not replaced after the tanking, hence my oil burning. i also pull great vacuum, 22-23 at idle once warm and about 26-28 when i am cruising and let off the gas
this was at normal operating temp, throttle plate wide open, 6 turns of the motor. this is how ive been doing it for a few years.
Old 07-29-2005, 11:33 AM   #21
Munkyw3rkz.webs.com
S@nt0s's Avatar
might have to check that out...
i ask kuz a lot of peeps do 5-6 and techs at HONDA say 10
Old 07-29-2005, 12:13 PM   #22
Teglove2's Avatar
Golden eagle sleeved 84.5mm ls block
Obx intake manifold(type r repica)
sfp race manifold
crower dual springs(soon to be 404's!!!)
mild p&p(3 angle valve job)
t3/t04e .63 ar hot side 60 trim compressor
3" downpipe to 3" straight pipe
aem ems with 3.5 bar map and aem wideband
custom 2.5" charge pipes
spearco 28.5x8x3
tial 38mm wastegate
Tuned by Tim Switzer to 373whp and 290 wtq on 18psi on pump gas with 11.8 degrees of timing advance on a 90 degree day!!!
Teglove2 is offline   Reply With Quote
Old 07-29-2005, 12:13 PM   #23
nicklk's Avatar
My setup:
94 Integra LS
81.5mm GE block guarded
JE SRP 10.5:1 pistons/Eagle rods
Head port and polished w/ Crower valve train
Crower 404 cams
AEM cam gears (I+4*, E-0)
Drag kit w/Tial 35mm WG
t3/t04e turbo
2.5" DP to 2.36" DP back
HKS SSQV bov
RC 550's
GSR tranny w/Quaife LSD
Exedy Organic racing clutch and ProLite FW
Motor built by me, Uberdata tuned by me:D
My fastest run so far is 12.71@106 on slicks on 6psi.....
Here is my vid...Here is a video of my second run
No dyno's yet, increasing the boost to 10psi this week and getting her on the rollers soon!
Modified by nicklk at 11:39 PM 7/29/2005
nicklk is offline   Reply With Quote
Old 07-29-2005, 12:18 PM   #24
DurboDug93's Avatar
DurboDug93,
time it yet????
No track times yet. I need to buy some drag radials or slicks first. Plus im on stock suspension
Quote:
Yeah man, you need to get that thing on the dyno. Im interested to see what gains you will get with those cams
Old 07-29-2005, 12:20 PM   #25
Munkyw3rkz.webs.com
S@nt0s's Avatar
Quote:
dont mock the stock shyt my homie ran 11.3 in a full weight GSR with 365whp slick down
set a new personal best last night blackeg Drag Racing 3 06-07-2007 12:43 PM
14.4 ls-t :( 93cicvicls Drag Racing 0 06-19-2005 12:38 PM
LS-T track times pushinlsteg Acura Integra 3 11-30-2004 09:15 AM
First time to the track with my setup sydag5 Forced Induction 6 03-29-2003 02:28 PM
Please post your idle and what fuel management/ injectors LS-T Forced Induction 32 03-22-2003 12:21 AM
Tags
b18, b18a, b18b, good, honda, hondata, hp, ls, lsturbo, manifold, meutek, motor, specs, stock, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
