Loud forged pistons ?
Hi I purchased this built boosted b18b1 back in November of last year and have always had a noisy diesel like engine sound . I adjusted the valves today which helped a lot as they were a bit loose but now I’m really noticing this almost like piston slap noise on acceleration. It’s not overly loud or easy to hear but it is there if you really listen . It’s louder on cold start but quietes down a lot as the car warms up . Here’s a video of the noise please tell me if this is normal . I’m about to get the car retuned and don’t want to spend money tunning if I’m gonna end up needing an engine replaced soon .
https://youtube.com/shorts/6Ut5cP_ONGA?feature=share
- Cp pistons
- Manley H beam rods
- ACL race oil pump
- cosmetic head gasket
- block is 20 thou over
- head resurface
- arp head studs
- arp connecting rod bolts
- gates racing timing belt
- acl race bearings
- aftermarket base pan
- aem fuel rail
- Vms racing fuel pressure gauge
- 255lph fuel pump
- cx racing intercooler kit
- HKS blow off vavle
- Skunk2 70mm throttle body
- aftermarket coolant over bottle
- 54mm precision turbo
- Cx racing wastegate
- Rev top mount turbo manifold
- autometer boost gauge
- aem wide band
- kteller 3 inch exhaust
- magnaflow race muffler
- 3 inch downpipe
- autometer oil pressure gauge
- manual boost controller
- hondata s300 Ecu
- 750cc grams injectors
- Omni 4 bar map sensor
- aftermarket distributor
- Cp pistons
- ACL race oil pump
- head resurface
- arp head studs
- acl race bearings
- aem fuel rail
- 255lph fuel pump
- aem wide band
- 3 inch downpipe
- hondata s300 Ecu
Re: Loud forged pistons ?
Sounds like a normal healthy idle to me.
Another video of revving the engine up or driving the car around a bit may help get a better idea.
Do you know what your P2W specs are? Or what your rings were gapped at? If you're paranoid you could do a compression test to make sure the engine is healthy, and/or a leakdown test to make sure you're not loosing compression in the cylinders.
Could also stick a cheap bore scope into the cylinder and make sure the piston dome and walls look good. But based on the short video you posted initially, it sounds healthy to me.
https://youtube.com/shorts/-aSTn46O1jo?feature=share
Getting the exhaust leak fixed would be the first course of action, that could definitely have an impact.
Engine still sounds overall healthy to me, possible that some of the tolerances are on the looser side of things but that alone isn't a big concern. So far, and plus the fact you're not burning oil, the engine seems healthy to me. I'd get the exhaust leak fixed and a proper full tune done.
You may end up needing to get the flange on the manifold/turbo resurfaced, and a new gasket on if the gasket maker doesn't work.
Good luck, enjoy the car.
I deff hear the exhaust leak!
Forged internals will be loud on cold start-ups and should get quit when the engine warms up.
