knocking noise at cold start
Old 12-23-2005, 05:58 PM
b20vtech's Avatar
Default knocking noise at cold start
motor knocks when i start (cold) then stops when it warms up..any advice?
Old 12-23-2005, 06:18 PM
HYBRID_H@TCH's Avatar
Default Re: knocking noise at cold start (b20vtech)
piston slap..
not much you can do but over bore it (new pistons) and set the piston to cyl wall clearance correctly..
Old 12-23-2005, 07:56 PM
clemsonteg's Avatar
mine does the same thing, I was told it wasnt a problem, thats what you get for having low silicone pistons, I was told just to not drive it until it warms up, other then that it should be ok, but someone else would be able to tell you better
Old 12-23-2005, 08:16 PM
Tooned's Avatar
Dude above is right. It's piston slap mine does it until it until it's warmed up temp. My clearances are a little loose. That's how it was built. It's normal.
Old 12-23-2005, 09:19 PM
b20vtech's Avatar
Default Re: (Tooned)
so that knocking noise shouldn't be a problem?
Old 12-23-2005, 09:21 PM
Who is Mr Robot?
wantboost's Avatar
Default Re: (b20vtech)
nope
Old 12-23-2005, 11:34 PM
AlphaQup's Avatar
Default Re: (wantboost)
Mine does the same thing. But I was thinking it was my LMA's.
People who've replaced their lma's before, does the knocking continue even after the car is warmed up, or does it go away as well?
Old 12-23-2005, 11:39 PM
SiKid86's Avatar
Default Re: (AlphaQup)
once the pistons expand (car warms up) it should go away
Old 12-24-2005, 12:56 AM
Default Re: (SiKid86)
mine has a very slight slap when dead cold but I set mine a little looser due to the rpm and power mine see's..wont hurt anything as long as you warm it up..
Old 12-24-2005, 03:52 AM
clemsonteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlphaQup &raquo;</TD></TR><TR><TD CLASS="quote">Mine does the same thing. But I was thinking it was my LMA's.
LMAs?
Old 12-24-2005, 04:03 AM
AlphaQup's Avatar
Default Re: (clemsonteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clemsonteg &raquo;</TD></TR><TR><TD CLASS="quote">
LMAs?</TD></TR></TABLE>
I guess you've never heard of lost motion assembly?
Old 12-24-2005, 08:06 AM
clemsonteg's Avatar
no I havent, I have never actually built a motor, so I know the basics, rods, bearings, mains etc. but I have never heard of lma's, where are they located and what are their purpose?
Old 12-24-2005, 09:35 AM
AlphaQup's Avatar
check the archives dude. There's plenty of info on lma's.
Old 12-24-2005, 12:36 PM
BiG Chris's Avatar
ive got the same thing in my chevy tahoe, when its cold it has a good slap to it but once warm it goes away, due to the work that the motor has to do it helps when your under load or boost
Old 12-24-2005, 12:47 PM
b18a1ef9's Avatar
Default Re: (BiG Chris)
i have a wrx and it has piston slap from the factory, i guess wrx's all have some piston slap when the car is cold. as long as it doesnt slap when its warm i wouldnt worry about it.
Old 12-24-2005, 12:50 PM
turbotime's Avatar
piston slapparoo
my built engine does this too- its just cause the pistons arent warm and havenbt expanded
Old 12-25-2005, 07:08 AM
Tooned's Avatar
LMA's are in the head under the middle rocker arm.
Their purpose is to keep the middle rocker arm from flopping around widely when the motor is not in vtec and keeps a little pressure on it
pootie.teng
03-12-2008 02:00 PM
AmginE
04-15-2004 12:56 PM
Nextelbuddy
03-01-2004 04:15 PM
GruvyTune
08-30-2002 12:54 AM
Trajic
11-15-2001 05:08 AM
Quick Reply: knocking noise at cold start
