just got my engine all back together and im having trouble with ignition timing
Old 03-20-2003, 07:51 AM
lsvtec101's Avatar
Default just got my engine all back together and im having trouble with ignition timing
im trying to get my car back to stock timing after the rebuild. i have the crank and camshaft set TDC. and its throwing my distrib off
shes firing on #3 instead of #1
how would i adjust the dizzy without throwing the camshaft off TDC
Old 03-20-2003, 09:55 AM
DD_JonnyLee's Avatar
Default Re: just got my engine all back together and im having trouble with ignition timing (aemcivic_02917)
it sounds like you might have the distributor 180 degrees out, rotate the button on cam side of the dizzy 180 degrees, give that a try
-jonathan
Old 03-20-2003, 09:58 AM
b18bturbo's Avatar
Default Re: just got my engine all back together and im having trouble with ignition timing (TrboGSR)
-jonathan
just what he said is correct.
Old 03-20-2003, 10:01 AM
93LSivic's Avatar
Default Re: just got my engine all back together and im having trouble with ignition timing (b18bturbo)
Just so you guys know. It is impossible to have the distributor installed 180 out.
Do you have adjustable cam gears? How much was the block decked, has the head been machined??
I would go back over cam timing again.
Old 03-20-2003, 11:06 AM
turbosol's Avatar
Default Re: just got my engine all back together and im having trouble with ignition timing (93LSivic)
There are two plugs in the vtec solinoid area one is green the other is gray and they can be switched. This happened to me when I was changing the tranny on my del sol, I thought something was up with the ignition but it ended up being those plugs being switched.
Old 03-21-2003, 01:12 PM
luckypon7's Avatar
Default Re: just got my engine all back together and im having trouble with ignition timing (turbosol)
does your distrubitor hole match up to bolt on, if not take distributor out match the hole where it can bolt on, make sure the think that goes in and match with the cam rod match up you should be able to move it around to do so. from the look of the picture the distributor is at a wrong position, the slot that screw drive needs to go in and losen the screw should be towards the back of the car.... hope you understand what i am trying to say, don't know the exact term.
Old 03-21-2003, 02:10 PM
legendboy's Avatar
Default Re: just got my engine all back together and im having trouble with ignition timing (luckypon7)
K, if you put your timing belt on correctly it shouldn't matter which cylinder is firing first!?
Old 03-21-2003, 03:31 PM
QCKGSR's Avatar
Default Re: just got my engine all back together and im having trouble with ignition timing (legendboy)
good luck
95_Civic_4dr
12-19-2010 08:28 PM
SouthSider13
10-15-2010 01:24 PM
johnwohl
04-01-2008 07:29 PM
JDMs1eeper
10-22-2003 10:01 PM
Alias
01-28-2003 06:56 PM
Quick Reply: just got my engine all back together and im having trouble with ignition timing
