Seeking advice/suggestions with this fresh build's problem.
Old 11-15-2009, 08:49 PM
DC4KiD's Avatar
Default Seeking advice/suggestions with this fresh build's problem.
all resolved. thanks for those who helped!
Old 11-15-2009, 09:06 PM
OUT OF ORDER ROB's Avatar
Default Re: Seeking advice/suggestions with this fresh build's problem.
Help Help Help
Old 11-15-2009, 09:38 PM
gsp ej1-em1's Avatar
dood, just tow it to your tuner and have them fix it. it could just be the tune after all.
Old 11-15-2009, 09:42 PM
YARO.'s Avatar
I agree with tune x2!!!
Old 11-16-2009, 05:27 AM
candy eg's Avatar
Location: The Real O.C. Oakland Chinatown, California, USA
bump. have a pretty similar problem and its frustrating as FAWK!!!!!!!!!!!!!
Old 11-16-2009, 05:32 AM
kyden's Avatar
do you have a wideband?
Old 11-16-2009, 02:21 PM
hybrdthry911's Avatar
blox c cams, no tune of course its gonna run like ****.
Old 11-16-2009, 03:22 PM
DC4KiD's Avatar
I'm on a TUNED ECU with the MATCHING GM 3BAR MAP Sensor. I understand that not all engines run the same even if they're nearly identical in setup, but Blox C cams themselves ain't gonna make my car mis-fire like crazy and fouling out my plugs.
kyden - I don't have a wide-band.
Old 11-16-2009, 06:40 PM
you put an aggresive cam in your car and expect it to run good. not sure what there is to misunderstand here. the car is untuned, an ecu from another car thats been tuned is not considered tuned.
Old 11-16-2009, 08:14 PM
DC4KiD's Avatar
Look, I'm not expecting it to run perfect, I just want it to run good enough for me to drive the car to the tuner. So what you're saying is, the crazy mis-firing is expected? ****, I hope not because I've installed cams in other cars (and my car with a prevous setup) and drove it UNTUNED OK just to get to the tuner. My car is UNDRIVEABLE to get to the tuner because of the problem.
And those cams aren't even that agressive; their profile is less than the B/Stage 2 cams.
Old 11-16-2009, 09:33 PM
i love ht. you ask for help and they give you criticism.
Old 11-17-2009, 12:37 PM
i love HT too. someone asks for help you tell them what could be wrong and they tell you, you are wrong.
Old 11-17-2009, 01:48 PM
NonovUrbizniz's Avatar
It sounds like an ECU problem... I'd try swapping in a stock ECU just to see if it will drive in gear OK... obviously don't go into boost... but if the problem is it's breaking up AS SOON as it's in gear and you try to drive it... chances are the maps are not setup right for your car.
Also you didn't give any relevant information...
WHAT ECU?
In what way is it "tuned"
What was your friends setup that ran fine with it? same motor/trans? same obd?
It's almost certainly your ECU or map.
Old 11-17-2009, 06:57 PM
DC4KiD's Avatar
Yeah... but what's so legitimate about "you have blox c cams, of course it's gonna run like ****"?
I know what it's like to run on aftermarket cams with a stock ECU, base map, and a tuned map from another car, and it's definitely not like what I'm experiencing right now.
WHAT ECU?
It's a chipped P28 dyno tuned with Crome on my friend's EK (2.0L C1, 469whp/382trq), both the MAP sensor and ECU are from that car, and were working just fine right before I pulled them out.
I have another chipped ECU that I can try swapping out the maps just incase one of them has been short-circuited some how.
It's boiling down to either the ECU or my wiring harness, since I did re-wrap it and did some soldering. I'm gonna open it up, and hopefully I'll find something obviously wrong (LOL).
Appreciate the advice!
loopedR6
10-10-2006 10:15 AM
turbo98lude
07-07-2005 02:40 PM
no2unenolife
01-25-2005 06:20 AM
JFG Kevin
09-23-2004 09:09 AM
Quick Reply: Seeking advice/suggestions with this fresh build's problem.
