hx40 hp?
Old 10-17-2011, 06:23 PM
88_hatch_ls's Avatar
Default hx40 hp?
does any one know what the max hp a holset hx40 would put out on a fully built lsv?
Old 10-17-2011, 07:41 PM
Hidenplanvew's Avatar
Default Re: hx40 hp?
ask shodan.. hes the man
Old 10-18-2011, 06:15 AM
Moderator
TheShodan's Avatar
HX40, HX40W and HE431 run close to about 70lbs/min at 3.2PR.
That means that maximum efficiency for use of that turbo is about 31-33psi of pressure. for 70lbs/min to be effective that's a bit over 600-700whp maximum. Doesn't matter if you're an LS/VTEC or a 383 stroker v8. the turbo can flow only so much. Some variances include which turbine housing you're using such as either 12cm^2 or 18cm^2. No one can guess your exact hp from this, but this is about the range you'll fall in, provided you have the correct supplemental components to aid in that kind of power
Old 10-18-2011, 10:24 AM
thx shodan u are the man! haha
Old 10-18-2011, 11:54 AM
told ya haha
Old 10-19-2011, 09:24 AM
Bseriescivic5's Avatar
would the HE351cw fall into this same category? To my knowledge the only difference would be the 9cm housing that the 531 uses. I think the wheels are identical though. FYI, I made 305/200 on a stock b16 at 10.8psi according to the datalog.
Old 10-19-2011, 09:50 AM
Moderator
TheShodan's Avatar
No. different wheels, different flow rate.
HE351 and HE300 series are about 52-56lbs/min at 3.0PR (29-30psi of pressure) maximum use.
Old 10-19-2011, 10:10 AM
Shodan how the french do you know so much about turbos?
Old 10-19-2011, 12:47 PM
turbohatch96y7's Avatar
Get off his sack get a job at mc donalds and ur gonna wonder why u know so much about bigs macs.
Old 10-19-2011, 02:26 PM
Moderator
TheShodan's Avatar
Former design engineer at Honeywell Turbo Technologies. You get used to this stuff after a while.
Old 10-19-2011, 03:39 PM
Both wheels are different? or just turbine? Thanks for the info, I didnt know the hx40 was a 70lb/min turbo
Old 10-19-2011, 07:42 PM
thats whats up bro
Old 10-20-2011, 05:06 AM
Moderator
TheShodan's Avatar
different wheel /shaft package entirely. HX40 can range from about 62lbs/min-70lbs/min MAXIMUM, depending upon housing size and which HX40 you have. there are several combinations.
Old 10-20-2011, 05:44 AM
Excellent info man, I really appriciate it. I will be pushing the He351cw a whole lot further, after studying its compressor map, Im not even in the first island untill about 1 bar of pressure... pretty stout OEM turbos
Old 10-20-2011, 05:54 AM
Moderator
TheShodan's Avatar
That's because they they were the only diesel turbos that were designed to take high rotational speeds. In the diesel world, they are considered to be HIGH performance. It just so happens that they can work somewhat effectively on gasoline powered engines.
Now, when it comes to rebuild or replacement of any components, that's a different story. You'll be more pissed off than ever, when you find you can't rebuild the damn things very cheaply or easily.
Old 10-20-2011, 07:22 AM
joppe's Avatar
Why holset is harder or more expensive to rebuild?
Old 10-20-2011, 07:42 AM
bgdriver's Avatar
That's what I was thinking, rebuild kits are all over ebay or you can get 'em at the Dodge dealer. I've had Holset apart and it was 1000% easier than the IHI turbo I did.
Old 10-20-2011, 11:09 AM
Moderator
TheShodan's Avatar
That's because 99% on ebay aren't the real parts (though most of the younger people don't care), and you're not accounting for replacement damage to wheels, shafts and housings. So go ebay if you must, but buyer beware. The IHI turbos are a b!tch to rebuild if at all. Especially the Subarus.
The ones from the Dodge dealer for the Cummins have to be machined to fit some of the other HX series wheels. Ask how much they want for a compressor cover or turbine wheel. Only then will you **** your pants at the price. (At least from what I recall)
When I say rebuild, I don't mean just some internal bushing kit. I mean THE WHOLE REBUILD. You're better off finding another used one. Just letting you know.
Old 10-20-2011, 02:24 PM
Thats what im thinking.... If I ever need to replace the turbo because of damage...etc; Ill just go out and buy another used one.... they can be readilly had for ~300bucks, if lubricated properly, shouldnt these turbos last 100k+ miles? hell they are OEM component, I would think they should be pretty reliable (assuming you have your supporting components)
Old 10-20-2011, 04:07 PM
joppe's Avatar
Theshodan how much is HY35 max hp / boost compressor 54/78 turbine 58/65 housing 9cm² ?
Old 10-21-2011, 05:51 AM
probably mid 400's mate.
Old 10-21-2011, 06:05 AM
Moderator
TheShodan's Avatar
Similar to HX35, about 53lbs/min-56lbs/min
Hehe..Alright, no more of HP expectations, I'm not much of a Holset fan. I may know a bit, but I'm no encyclopedia for them. different housings will give different results on similar types. They all run within the same family.
HX30,30W/HY30/HE300 - 35lbs/min range
HX30,30W/HE300 - 33lbs/min range
HX32W/HY35W/HX35/35W - 55lbs/min range
HX35,35W/HX35/40, HX40W/ HE431 - 70lbs/min - 80lbs/min depending upon turbine wheel and housing.
and a billion others.
Old 10-21-2011, 06:31 AM
hahah, you must get at least 5 PMs a day reguarding turbo choice/specs.... hope it doesnt get too annoying, thanks again for the information.
Old 10-21-2011, 10:50 AM
Moderator
TheShodan's Avatar
No worries. I get an average of about 15/day. I never mind helping, but when its just questions of XXHP for XX Turbo with no additional input, it gets a bit gruesome. I'm not a vending machine just spitting out a can of answers based on a button, ya know?
Old 10-21-2011, 01:40 PM
joppe's Avatar
I appreciate all your help to random people, your posts are awesome.
/offtopic
Quick Reply: hx40 hp?
