whos running a borg warner s352
Re: (flatblackhatch)
i havent seen the turbo perform on any 1.6L sad to say, so im not to sure how it will fair out. if you want a bw turbo for your b16 look at the s256 and s258
Re: (tony413)
we already bought it and shodan recomended it to us just havent got it on the dyno yeat but when we do ill post are numbers
Moderator
The S362 in the T3 .70A/R is capable of 600whp. Will it do "10s"? That's up to you the driver and your supplemental equipment. Don't rely only on the turbo to do what you're trying to do. Focus on the rest of your setup, and seat time. If you know how to drag race, you'll eventually do it.
Re: (TheShodan)
well ive got two years in the seat of this car so hopefully wont be that hard to do we where running 11.88 @119 with 338whp on a precission t3 57 trim 60 ar and basic revhard kit. cast mani revhard tiny fmic turbosmart wastegate 550 injectors and 19.5lbs so im hoping this will put us over the edge for tens.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flatblackhatch »</TD></TR><TR><TD CLASS="quote">well ive got two years in the seat of this car so hopefully wont be that hard to do we where running 11.88 @119 with 338whp on a precission t3 57 trim 60 ar and basic revhard kit. cast mani revhard tiny fmic turbosmart wastegate 550 injectors and 19.5lbs so im hoping this will put us over the edge for tens.</TD></TR></TABLE>
work on your suspension and bump power up to 380Whp or 400Whp and work on getting good 60ft. times and you will be in the 10's. you dont need 600whp to try to muscle the car down the track
Re: (tony413)
the turbo we had ran out of room i was pulling 1.7 60s with that setup which are decent. im just hoping to hit tens as far as the car go its got everything on it suspension wise to help hook it up i know its going to take some tinkering to get it to ten but im just wondering if with that setup we have potential. its b16 stock bore sleeved aries pistons 9.1 to 1 crower rods stock crank ferra valve train springs retainers all that good stuff using gsr cams victor x mani peakboost topmount mani precission 650fmic 3in dp tuning using s300 and running 30lbs.
