How to install 3 bar map sensor?
How to install 3 bar map sensor, i know the wiring i want to know how should connect it to throttle body?
Re: How to install 3 bar map sensor? (CiViC SiR)
all you do is run vaccum line from the intake mani to the Map sensor. then you wire it to your standalone
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CiViC SiR »</TD></TR><TR><TD CLASS="quote">any vaccum line in intake mani?</TD></TR></TABLE>
you want to have a dedicated line for a map..i.e. no t's or anything into it...and also make it as short as possible. i wouldnt go any longer then 8"
Re: How to install 3 bar map sensor? (shermanyang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang »</TD></TR><TR><TD CLASS="quote">how are you running 18 psi without a 3 bar map sensor in the first place?? don't tell me you're running check lines!!?? </TD></TR></TABLE>
missing link
missing link
With the missing link you can run more than 11 psi (stock map sensor)? How do you wire it up using a hondata s100 w/boost?
jeffchaisi
03-27-2005 10:39 PM
