How to identify a Zex / Comp cam? - Honda-Tech
Old 04-04-2006, 12:45 AM   #1
Default How to identify a Zex / Comp cam?
I bought a cam from a guy here on H-T. It should be part #105300 (for a d16y8 motor).
The box had the correct number on it, but the cam didn't. The only number stamped on the cam was 05008.
I don't know what that means. Everyone is telling me that 105300 should have been stamped on the cam. Is that right?
Also, out of curiousity, does the presence of rough casting metal in between lobes indicate that a cam is billet?
EnzoSpeed is offline   Reply With Quote
Old 04-04-2006, 10:07 PM   #2
Default Re: How to identify a Zex / Comp cam? (EnzoSpeed)
Hmmm... nothing? No one has one lying around that could check for me?
98 civic with y7/y8 mini me - Idle adjustment question Dan_Brutal Honda Civic / Del Sol (1992 - 2000) 4 05-28-2015 04:36 AM
D16Y8 Comp Cams 105300 - Rough Idle mdrouillard1983 Honda Civic / Del Sol (1992 - 2000) 1 05-08-2015 06:35 PM
93 Civic Hatch Si Reg. NV FT _EF9 Northern California (Sales) 2 04-07-2014 05:26 AM
Zex 95300/105300 cam valve lash question Pfieff Forced Induction 15 01-21-2009 01:14 PM
Identify a comp 59100 cam? s1ngle Forced Induction 9 12-11-2006 08:11 PM
Tags
acomp, cam, cams, camshaft, camshafts, casting, comp, honda, identify, identifying, number, part, stamped, zex
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
