how do i tell what size my turbo is? - Honda-Tech
Old 01-09-2004, 05:09 PM   #1
yusoslo's Avatar
Default how do i tell what size my turbo is?
i got a turbo kit for my d16 and the turbine wheel has a number 203-59 on it
and the compressor side has 3057 on it.
I was told it is a t3 and it seems logical the compressor wheel is a 57 trim
also when i play with the shaft it wiggles a little bit ( I have to push hard to make it move) when the turbine blades move it doesnt touch the walls, comes close but doesnt touch. I would say it has very little movement and it requires some pushing to make the shaft "play" is this anything to be concerned about?
yusoslo is offline   Reply With Quote
Old 01-09-2004, 05:19 PM   #2
99blackcivicSi's Avatar
Default Re: how do i tell what size my turbo is? (yusoslo)
I don't think so, how long has the turbo sat? if it hasn't been used in a while it will not spin freely it is called shalack (sp?) that has built up on the shaft once you start playing with it alot or put it on the car it will spin freely after that, a little shaft play is normal don't worry, if you have a BB and you have shaft play then that is bad. hope taht helped.
99blackcivicSi is offline   Reply With Quote
Old 01-09-2004, 05:53 PM   #3
yusoslo's Avatar
Default Re: how do i tell what size my turbo is? (99blackcivicSi)
that makes me feel more comfortable.
So is there a special place to look for the turbo sizing numbers? there is nothing on the face of the compressor housing, just on the backside where the shaft housing joining the two turbines is.
Old 01-09-2004, 11:19 PM   #4
yusoslo's Avatar
up
Old 01-10-2004, 09:03 AM   #5
yusoslo's Avatar
so there is no universal place to look?
Old 01-10-2004, 09:44 AM   #6
Bailhatch's Avatar
the A/r ratios are usually found stamped inside the inlet of the turbine, might have to scrape some crap off to see it. A/r can be found inside the oulet of the compressor cover also. To find out if it is a T3 flange just measure the opening in the turbine inlet, 95% of them are the same it should be 1.83" X 2.34".
There was some post on here about determining the wheel trim by measuring the minor dia with the housings still on. I can't find it or remember what the concensus was, anyone know what i'm talking about?
Bailhatch is offline   Reply With Quote
What to worry about when buying a Used turbocharger TheShodan Forced Induction 37 06-08-2013 06:27 AM
compressor wheel touching housing ninjaturtleEG Forced Induction 8 06-18-2012 03:04 PM
Compressor housing/wheel? VTECth1s Forced Induction 4 09-09-2011 02:19 PM
FS: Precision SC-4431E dephtone Classifieds: Forced Induction 2 02-08-2009 06:40 PM
Precision GT35E/T4 Weird problem... center section loose, bolts are tight g2turbo Forced Induction 5 07-09-2007 10:15 AM
Tags
ar, big, compressor, find, has, honda, hot, is, kno, size, sizes, turbine, turbo, wat, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
