how to calibrate e-manage to gm 3bar map sensor?
Old 05-26-2006, 07:54 PM
abmerop18's Avatar
Default how to calibrate e-manage to gm 3bar map sensor?
i am about to install a gm 3 bar map sensor on my 7thgen and need to know how to calibrate my e-manage so that it has the correct boost reading since i am switching from a 1 to a 3 bar map sensor. any help would be appreciated. thanks.
Old 05-27-2006, 07:36 AM
abmerop18's Avatar
Default Re: how to calibrate e-manage to gm 3bar map sensor? (abmerop18)
anyone?
Old 05-27-2006, 08:45 AM
Moderator
TheShodan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abmerop18 &raquo;</TD></TR><TR><TD CLASS="quote">anyone?</TD></TR></TABLE>
You don't use the GM 3bar map sensor for the Greddy e-manage. You would use the Greddy Pressure sensor (which is 3 bar) to hook up to the unit. The original manufacturer is DENSO, and they use the same pressure map sensor as the APexi' Power FC. If you MUST use the GM 3 bar sensor, plan to change managment altogther for best results, but the pressure sensor from Greddy isn't that expensive, and can be easily ordered.
Old 05-27-2006, 11:28 AM
abmerop18's Avatar
Default Re: how to calibrate e-manage to gm 3bar map sensor? (TheShodan)
i have the pressure sensor alredy, i was under the assumption that it was used to control the voltage clamp and that it wasnt a map sensor in itself?
Old 05-27-2006, 12:50 PM
mike93boost's Avatar
you need the greddy pressure sensor. yes it is a 3 bar map sensor.
Old 05-27-2006, 02:51 PM
Moderator
TheShodan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abmerop18 &raquo;</TD></TR><TR><TD CLASS="quote">i have the pressure sensor alredy, i was under the assumption that it was used to control the voltage clamp and that it wasnt a map sensor in itself?</TD></TR></TABLE>
No it IS the map sensor. It works in conjunction with your STOCK OEM map sensor. Youd don't disconnect the one to use the other. this really helps with a smooth transition.
Old 05-27-2006, 04:07 PM
abmerop18's Avatar
well i am throwing a code for high voltage to the map sensor. what should i do to solve this then?
Old 05-28-2006, 07:45 PM
Weq
Weq's Avatar
adjust the boost cut limiter to a lower voltage. for odb2 civics it should be a max of 2.95v, 2.9v to be safe.
DOnt ask around here for this kind of stuff, look onthe yahoo emanage group. There is a heep of information on how to use a GM 3bar instead of the greddy pressure sensor. Its very easy and these guys are just haters who have no idea what they are talking about!
Legion
04-14-2007 10:47 AM
weiRtech
02-26-2006 12:39 PM
agratise
02-24-2005 05:48 AM
This One
02-20-2004 07:19 AM
Quick Reply: how to calibrate e-manage to gm 3bar map sensor?
