bullseye s362?????
Old 04-12-2010, 06:59 PM
sanman000719's Avatar
Default bullseye s362?????
does it come in a t3 foot print, and whats the power that has been made off of it
Old 04-13-2010, 06:41 AM
irishflame27's Avatar
Default Re: bullseye s362?????
yes T3, and they can make around ~680whp
Old 04-13-2010, 09:52 AM
Moderator
TheShodan's Avatar
there are 3 T3 footprint choices. a .55A/R, .70A/R and .85A/R. The .55A/R uses a P-trim exhaust wheel, while the .70A/R and .85A/R use an 80mm exhaust wheel in a cast V-band only. The .85A/R uses a 6 bolt turbine housing that has a difficult to find flange. the most power made from the T3 footprint is usually found in the.70A/R 3" v-band. For space concerns, only use the S300 cover of the S362 if you plan to use a top mount. Otherwise, use the S200 cover option (S262), which is about 7" in diameter to fit most bottom mounted turbo manifolds.
B_Swapped93
03-05-2015 07:49 AM
NZXTInerTia
05-12-2013 07:10 PM
boostedteg909
01-28-2013 04:59 PM
untitled
12-25-2004 10:42 PM
eddie1681
03-03-2002 07:50 AM
Quick Reply: bullseye s362?????
