HOW TO: Boost gauge readings: pounds lbs to khpa to bar conversions - Honda-Tech
Old 04-11-2004, 08:38 PM   #1
Civiclx's Avatar
Default HOW TO: Boost gauge readings: pounds lbs to khpa to bar conversions
did a search, I have an autometer boost gauge and a blitz dtt turbo timer that reads boost in khpa, does anyone know how to convert these measurements?
Civiclx is offline   Reply With Quote
Old 04-11-2004, 08:44 PM   #2
TurboTegB18c's Avatar
Default Re: HOW TO: Boost gauge readings: pounds lbs to khpa to bar conversions (Civiclx)
1 bar is equal to 14.5 psi. so u take whatever bar u get and multiply by 14.5 and that's ur psi.
TurboTegB18c is offline   Reply With Quote
Old 04-11-2004, 08:54 PM   #3
alpha's Avatar
alpha is offline   Reply With Quote
Old 04-11-2004, 08:54 PM   #4
Civiclx's Avatar
Default Re: HOW TO: Boost gauge readings: pounds lbs to khpa to bar conversions (TurboTegB18c)
is bar the same as hkpa? because my turbo timer reads it in hkpa? i thought bar was kg/cm^3
Old 04-11-2004, 08:59 PM   #5
Civiclx's Avatar
looks good, but what about hkpa and mpa (wrx stock gauges)
Old 04-11-2004, 11:00 PM   #6
EFb18b's Avatar
Quote:
14.5psi = 1 bar
1 bar = 1.0197 kg/cm^2
EFb18b is offline   Reply With Quote
Old 04-11-2004, 11:05 PM   #7
For the V/SAFC guys:
(kg/cm^2) = PSI
.035 = 0.5psi
.070 = 1.0psi
.105 = 1.5psi
.141 = 2.0psi
.176 = 2.5psi
.211 = 3.0psi
.246 = 3.5psi
.281 = 4.0psi
.316 = 4.5psi
.351 = 5.0psi
.387 = 5.5psi
.422 = 6.0psi
.457 = 6.5psi
.492 = 7.0psi
.527 = 7.5psi
.562 = 8.0psi
.597 = 8.5psi
.633 = 9.0psi
.668 = 9.5psi
.703 = 10.0psi
.773 = 11.0psi
.843 = 12.0psi
.914 = 13.0psi
.984 = 14.0psi
1.00 = 14.23psi
Hoosier Daddy is offline   Reply With Quote
Old 04-12-2004, 03:12 AM   #8
MiraiZ's Avatar
Default Re: HOW TO: Boost gauge readings: pounds lbs to khpa to bar conversions (Hoosier Daddy)
there must be tons of conversion calculators on the net
MiraiZ is offline   Reply With Quote
Old 04-12-2004, 06:26 AM   #9
Honda Hick's Avatar
Default Re: HOW TO: Boost gauge readings: pounds lbs to khpa to bar conversions (MiraiZ)
Quote:
I like this site the best. It converts EVERYTHING.
http://www.convert-me.com
1 psi = 6.895 kilopascal (kPa) or 68.95 hectopascal (hPa) or 0.06895 bar.
I don't see a khPa, but I'm assuming it is kPa.
Honda Hick is offline   Reply With Quote
Old 04-12-2004, 06:32 AM   #10
DaX
Actually,
1 bar = 10^5 Pa, which is approx. 1 atm, or 14.7 psi.
Just do a google search on pressure conversion, there are tons of websites.
DaX is offline   Reply With Quote
Old 04-12-2004, 08:19 AM   #11
Civiclx's Avatar
Default Re: (DaX)
Quote:
Originally Posted by DaX
Actually,
keep in mind that is atmospheric pressure which is completetly different than a manifold vacuum
Erratic boost reading on autometer gauge??? FRernesto Forced Induction 2 08-29-2007 08:01 AM
VAFC pressure reading converted to boost psi??? FastNFurious Forced Induction 3 02-27-2004 08:45 PM
Question on hooking up the boost gauge. navz121 Forced Induction 10 12-30-2003 10:23 PM
electronic boost gauges 94dxt Forced Induction 2 05-15-2003 01:31 PM
Question on vacuum reading on my boost gauge? BLKMamba Forced Induction 9 07-27-2001 11:47 PM
Tags
12, 15, bar, blitz, boost, conversion, converted, dtt, guage, khpa, lbs, mpa, pounds, psi, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
