Honda Wideband 5 wire O2 sensor... Wiring question
I did a search, found nothing.
I need to know wich wire does what.
thanks
Does it use the same color code as the NTK sensor, like on this picture ?
thanks
Re: Honda Wideband 5 wire O2 sensor... Wiring question (meanteg)
from what i know, but not 100% sure. the oem honda 5-wire is made by ntk so the wires should be the same color... can anyone correct me if im wrong?
Re: Honda Wideband 5 wire O2 sensor... Wiring question (9psiTurboSI)
that diagram is for the NTK sensor, which is the EXACT sensor you have.
follow that diagram and you should be good.
brad
brad
Powered By Garrett
02-17-2007 08:31 AM
