HMT doing "Turbo Kia"
Old 03-29-2005, 11:22 PM
AbaZ's Avatar
Default HMT doing "Turbo Kia"
Well some of you know I do work at a Kia dealership as a technican, last month I was able to talk my boss into letting me turbo a used 02 Kia spectra on the lot.
Picked out this one, we werent in the car very much, it didnt have AC and it has around 40k miles, seemed to be perfect for the job.
Keeping it "HMT" I decided to go with a nice used DSM T25 I had laying around. This was the first initial test fit, using coat hangers I was able to mock where I wanted everything.
Heres the base plate I used to weld the manifold so it didnt warp, I had to order a custom head flange from davesport since nobody makes head flanges for kias
I went with a unique style manifold, I wanted it to be different than anything I've seen, its basically like a reverse ram horn.
Using several Mcmaster 304L stainless steel 90 degree bends (sch 10) w/ a shitbird collector.
A shot of the stock manifold w/ precat vs the custom turbo mani and dsm t25 turbo.
Another angle
First test fit went very well, as you can see the mani is bling blinging, I spent several hours grinding down the welds and polishing the pipes.
Using a Stealthmode oil feed line kit w/ tuner toys block fitting.
A bit close to the alternator, but it fit pretty nice and length was perfect.
Shot of the T25, as you can see the compressor housing has been modified, I had to aim the neck so it aimed towards the pass side. (full 180 degrees)
The coolant fittings were also moved around a bit to aim towards the driverside.
Mocking up the oil return, just used a barbed fitting off the tunertoyz return fitting to a section of the stock dsm return pipe to a chunk of pipe welded into the oil pan.
Here is the Upper IC pipe, there are 2 Injector bosses welded in holding 2 DSM 450cc injectors
Using braided -6 an line and fittings, the fuel is T'd off the end of the stock fuel rail (returnless system)
Controlling the 2 injectors is the SDS EIC (Simple digital system Electronic injector controller) this was the first time I've ever used one but I thought it might work pretty decent for this setup. They are very easy to install, you basically have 2 ***** on the controller. One to set when the injectors come on in (vac/boost) and the other is threshold (how much the injector is injecting) it has a pretty cool led showing duty cycle. I had a bit of a tough time getting a good tach signal but I got it all figured out today
The 2 coolant lines ran from the turbo w/ barbed fittings 5/16 (EFI fuel line works great for this hose) All the Charge pipes (other than the corners) are painted high temp flat black. Using tunertoyz silicone couplers and a few from napa too!
2 lines tapped off the PCV line, one for the boost gauge and 1 for the map sensor that is build into the SDS EIC.
Using a 6in Custom Coach intercooler and 2.5 stainless steel bends, came out real nice and fit pretty well. In order to get the pipes to show through the fog light holes relocating of the washer bottle (up 1in) and coolant overflow bottle (left 4 inches) was neceassary. I think it came out pretty nice.
Using 2.5 IC piping on the Left side
and using 2.25 piping on the right then flaring to 2.5 before the IC
Heres a shot of the downpipe setup, as you can see I used a Electronic 3in cutout from Mccord power plate.
All painted high temp black, the dump sits right in front of the right tire.
Since the precat was removed I had to relocate the rear o2 sensor behind the primary cat convertor. Sensor 1 sits in the stock DSM o2 housing. All the wires were lengthend about 2-3 feet.
Tuning was a big concern since I didnt want to blow the thing up, Kia engines are pretty strong from the factory. Huge rods, friendly compresson ratio, solid deck, cast block, and a tripple layer steel head gasket. I used my zeitronix wideband and our factory Kia High scan pro when doing all the tuning.
It wouldnt be a true hmt setup if the ecu wasnt laying on the pass floorboard also check out the sweet install on the boost gauge haha.. this is temporary until I can figure out where its going.
Lowered on Intrax springs sitting on Rota Grid 17in wheels (PM DRFlickner for great deals on Rotas!)
Came out pretty decent looking for a 4door I guess, I'm not to big of a fan of the styling but whatever.
I ripped off all the "Kia Spectra" badges in the rear and added the classic dark grey HMT sticker.
All done, I used a honda battery in this thing because the upper IC pipe was just too close and it fit pretty decent. Overall I think this is probably the nicest setup I've ever done, I underbid the job bigtime and just glad its done. It still needs a bit of tuning here and there. Running a "solid" 8psi with the standard 10psi creep from a roll on. Hard to say how much power it made, feels decent for a Kia I guess. Not sure if we are going to dyno it or not, there are lots of people interested in buying it. Need to fix up some body damage and its going on the lot for sale!
My boss and the owner of the company want me to do another one, but I think I'm gonna pass.
This write up was a big vauge.. I'm just super tired and am so glad I'm leaving for vegas tommorow ;D
Hope you enjoy the pics! Any questions or anything shoot!
Special thanks to
CustomCoach (Anthony)
Tunertoyz (Craig)
Stealthmodeperformance (Steve)
DRFlickner for the wheels!
Jeff
Modified by AbaZ at 12:49 AM 3/30/2005
Old 03-29-2005, 11:29 PM
JSpin's Avatar
man, you should get a bonus or something for this project, it appears that you put in a lot of extra hours to get this thing done.
anways, looks good man!
also, if you would mind sharing a bit more about your SDS experience. i had an old school toyota celica in high school that i was looking to do a cheap turbo setup on, and i had planned on'tn doing SDS, but never got around to it. just wondering what your overall thoughts were
Old 03-29-2005, 11:35 PM
Timmay's Avatar
Default Re: HMT doing "Turbo Kia" (AbaZ)
very good work!!!!
how much does that 3" E-cutout go for?
Old 03-29-2005, 11:38 PM
ComputerJLT's Avatar
in before the home made setup hatred fromt he h-t retards
nice setup AbaZ quality workmanship there
Old 03-29-2005, 11:40 PM
littledan's Avatar
woah! great write up and very clean work! wow!
Old 03-29-2005, 11:41 PM
AbaZ's Avatar
Default Re: HMT doing "Turbo Kia" (Timmay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">very good work!!!!
how much does that 3" E-cutout go for?</TD></TR></TABLE>
http://www.mccordcg.com/mpp/mpp.htm
Jspin, I'll letcha guys know more about the SDS once I get a bit more fimilar with it, today was the first day I got the thing working right. My first panty ripper consisted of the dsm blow off valve shooting out raw gas out like old faithful, hahaha.
This turbo spools so god damn fast its adding fuel in the wrong spots, I think the SDS was designed for T4's or D-series because it adds a **** ton of fuel on the top and not enough in the low-mid range. I'm still working with SDS to see if we can get this resolved, they may just remap my chip for me.
Jeff
Old 03-29-2005, 11:42 PM
mtber's Avatar
Clean work!
Old 03-29-2005, 11:57 PM
the son and the heir
macrosshn's Avatar
stellar work AbaZ.
Old 03-29-2005, 11:58 PM
DLB1994's Avatar
Default Re: (mtber)
nice clean setup very good job
Old 03-30-2005, 12:00 AM
elitesi8's Avatar
My buddies over at http://www.truboost.com are doing a turbo kia as well
Old 03-30-2005, 01:01 AM
liam821's Avatar
Default Re: HMT doing "Turbo Kia" (elitesi8)
Nice work Jeff!! I dig it! You guys gotta get it on the dyno.
Did you design/weld that manifold yourself? It came out really good!!
liam
Old 03-30-2005, 03:22 AM
Finland's Avatar
Nice job on doing a custom setup on a bastard platform like the Kia. I think your boss is right in trying to get you to do more and you should. This kind of thing creates a lot of excitement and gives brands like Kia some hope in the performance sector.
BTW, I can just visualize a puff of fuel coming out of that blow off valve......good thing it didn't ignite...
Old 03-30-2005, 03:35 AM
H.A.R.T B18C1EG6's Avatar
Default Re: (Boondock Saint)
HAHAHA NICE JOB
Old 03-30-2005, 04:07 AM
yellowturbo's Avatar
Default Re: (P.S.H B18C1EG6)
to be different !
Old 03-30-2005, 04:14 AM
mrbsponge's Avatar
sweet deal bro! pure HMT style
Old 03-30-2005, 04:30 AM
quis23's Avatar
Default Re: (mrbsponge)
sweet !!
Old 03-30-2005, 06:16 AM
VTC_CiViC's Avatar
Default Re: (quis23)
Awesome work!!
Old 03-30-2005, 06:22 AM
kr
kr's Avatar
nice job
Old 03-30-2005, 06:23 AM
kr
kr's Avatar
Default Re: (kr)
please put it on the dyno.
Lets SEE some numbers.
Old 03-30-2005, 06:47 AM
mattEG's Avatar
That is awesome!
Dyno that bitch!
Old 03-30-2005, 07:10 AM
EJ1 wilcox's Avatar
Default Re: (mattEG)
Awesome work
I want to see some videos!
Old 03-30-2005, 07:52 AM
93turbo16's Avatar
that is awesome man. Clean setup. Kia would be surprising at a redlight.
Old 03-30-2005, 07:59 AM
W O T's Avatar
Default Re: (93turbo16)
Old 03-30-2005, 08:11 AM
SOHC_MShue's Avatar
damn that setup is very impressive. You need to take it to the track before selling it
Old 03-30-2005, 08:49 AM
CarpAngler's Avatar
Great Work
Quick Reply: HMT doing "Turbo Kia"
