Hey Turrrbo experts... is this worth it?
I was looking on ebay at some turbo kits, and this one caught my eye....
for about $850 after shipping, it has everything, turbo, manifold, intercooler, heres what it says...
STONE RACING PRESENTS:
H22 SERIES TURBO KIT
TO4E TURBO KIT
YOU GET
( ALL BRAND NEW IN THE BOX )
MANIFOLD
TURBO - T3/T4 V-BAND T04E HYBRID
TURBO DOWNPIPE
WASTEGATE 38MM BRAND NEW
WASTEGATE DUMP TUBE
FLANGES
GASKETS
FLANGE FOR BOV
FLANGE KIT FOR WASTEGATE
OIL LINE - BRAIDED AND TESTED
OIL DRAIN FITTING
10 VARIOUS TURBO FITTINGS / BARBS
HOSE / CLAMP / TBAR
Fits any H22-series motor
T3/T4 TURBO INFO ( H22 PRELUDE ) SERIES
TURBO
3" INLET DIAMETER
2" OUTLET
WET FLOATING BEARINGS
1/8 NPT OIL INLET
T3 / T4 FOOTPRINT OK !!
SPECS:
.50 A/R / .58 HOT SIDE
STAGE iv WHEEL
TURBONETICS CAST HOUSING
BALANCED AND BLUEPRINTED AND COMPRESSION TESTED
SUPER V-BAND EXHAUST
INTERCOOLER
24 " X 12 " X 75mm THICK
BAR AND PLATE SUPER INTERCOOLER = POLISHED
INTERCOOLER PIPES
is this a good deal? it sounds pretty good to me? do you think ill run into any problems in the future with it? thanks a lot...
TO4E TURBO KIT
YOU GET
MANIFOLD
TURBO DOWNPIPE
WASTEGATE DUMP TUBE
FLANGES
GASKETS
FLANGE FOR BOV
OIL DRAIN FITTING
HOSE / CLAMP / TBAR
TURBO
3" INLET DIAMETER
2" OUTLET
1/8 NPT OIL INLET
SPECS:
STAGE iv WHEEL
INTERCOOLER
INTERCOOLER PIPES
Screw you guys, I'm... going... home.
Re: Hey Turrrbo experts... is this worth it? (gotb18)
Short answer: NO! Anything from Stone Racing isn't worth a handful of monkey poo.
Long answer: Just search for "Stone Racing" or "SSAutochrome" and you'll learn more than you ever wanted to about the crap products they sell. Heed the warnings or you'll have to do it all over again anyway and then we'll flame you for it when you eventually whine about it.
Edit: You've been a member of H-T for over a year and you haven't seen the eleventy billion posts already made about them? What the hell is wrong with you? Are you blind or retarded or something?
Re: Hey Turrrbo experts... is this worth it? (tjbizzo)
yeah i think i am half retarted
does anybody else know where i can get a good quality turbo kit from?
Re: (Zakar)
i want it to be less than 1500 for everything, and i want to be able to boost it to like 15psi on a sleeved block with aftermarket pistons and rods... plus you got any suggestions on the pistons and rods? ill probably have darton sleeves..
Re: (gotb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotb18 »</TD></TR><TR><TD CLASS="quote">i want it to be less than 1500 for everything, and i want to be able to boost it to like 15psi on a sleeved block with aftermarket pistons and rods... plus you got any suggestions on the pistons and rods? ill probably have darton sleeves..</TD></TR></TABLE>
you are spending so much money on a nice engine, why not spend alil more for a nice kit? why half *** it? this is something i will never understand.
Re: (Zakar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zakar »</TD></TR><TR><TD CLASS="quote">could always do a junkyard build.. but it requires a little more knowledge</TD></TR></TABLE>
that is what i did. im just having problems with other ****
audiko4
04-30-2010 09:44 AM
Jdm94Coupe
04-09-2010 11:54 AM
