Help with ZC head gasket problem
I blew my head gasket and want to change it. I want to get a better one since i'm turbocharged now. My questions is whats the process to remove the camshafts and what gasket would you recommend me? Thanks for any help.
Re: Help with ZC head gasket problem (ZippyZivic)
Use a metal headgasket. If you are talking about a dohc ZC - there is only one metal headgasket and thats the HKS. If you have a sohc ZC, id recommend using a d16y8 headgasket as they are cheapest.
liam
liam
Re: Help with ZC head gasket problem (liam821)
yeah i'm talking about the DOHC ZC. I seen that HKS is bigger than 75mm those that make a difference i think it's 76mm. Whats the pattern to take of the cams? Anyone?
Re: Help with ZC head gasket problem (quis23)
I already saw the patter to take of the head bolts but i'm reffering to the cams that are on the way of the headbolts. In order to get to the head bolts i need to take of the cams that the pattern i'm looking for
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZippyZivic »</TD></TR><TR><TD CLASS="quote">yeah i'm talking about the DOHC ZC. I seen that HKS is bigger than 75mm those that make a difference i think it's 76mm. Whats the pattern to take of the cams? Anyone?</TD></TR></TABLE>
Yeah its 76mm - but that wont matter. I run the 76mm gasket on my 75mm bore without issue.
As for removing the cams - it doesnt really matter that much. I undo the cam bolts in the outside and work my way in. You wont snap a cam, and since the motor isnt spinning it wont hurt anything.
liam
Modified by liam821 at 10:50 PM 10/10/2006
liam
since you probably done a head gasket job would you recommend me to take the head off with the intake manifold connected since i want to put bigger injectors? Thanks man
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZippyZivic »</TD></TR><TR><TD CLASS="quote">since you probably done a head gasket job would you recommend me to take the head off with the intake manifold connected since i want to put bigger injectors? Thanks man</TD></TR></TABLE>
I take it off with the intake manifold connected since its easier. But either way works whatever is easier for you.
liam
liam
one last question. I was thinking of a port and polish and griding the cams is this really worth it or is it a waste of money i can invest it somewhere else?
camshafts should be removed by loosening cam caps from the outside in, in a couple steps. vavle spring pressure is acting on the cams and if taken off in the wronge sequence you could break a cam. As a general rule loosen from the outside in and tighten from the inside out in a criss cross pattern, you will end up with less warped and broken parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZippyZivic »</TD></TR><TR><TD CLASS="quote">one last question. I was thinking of a port and polish and griding the cams is this really worth it or is it a waste of money i can invest it somewhere else?</TD></TR></TABLE>
The dohc ZC responds well to cams. A ported head wont help much until you try to push more then 350whp.
liam
liam
I called a place to order the head gasket for my ZC DOHC from hks. But the guy who helped me said that the one they sale if for a d16a1/zc but that the DOHC was different is this right or was he just a little confused?
cometic makes a gasket for that.
endyn carries D stuff in stock in varous sizes so you could contact them if your in a rush.
http://www.theoldone.com
Re: (oscarmayer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oscarmayer »</TD></TR><TR><TD CLASS="quote">cometic makes a gasket for that.
Cometic does offer one, but by all means get the HKS if at all possible. It will be listed as the D16A1 gasket at many places, but it is the ZC/D16A1
