Help Id'ing my turbo? Pics inside!
It's says 34 31 E
If it helps any, on the compressor side, the outlet is 2"
Through trading stuff I got this turbo (along with all the other goodies to run it) for free and I'd like to know what I'm dealin with here so I can know abotu how much boost I can run,since 2 lbs on one turbo making xx hp isn't always the same on another turbo at 2 lbs.
I'd appreciate any help guys! I'm doin my best to learn all I can and I've got alot from this forum!
Terrance
Modified by mac_24_seven at 4:29 AM 8/19/2008
Modified by mac_24_seven at 5:09 AM 8/19/2008
Your .60 AR is on the compressor side - that is fine because it's a T04E housing.
The .63 AR is for the hotside - look at the inside of the exhaust housing, it should be stamped ".63"
Re: (EJ8 944)
Which requires removal of the manifold, correct?
Plz excuse my ignorance, I've been getting a crash course is turbos as of late. It makes sense to me that the inlet is what is connected to the manifold.
Plus I wanna make sure before I break it apart.
According to your pics, the turbo isn't installed on the manifold..
Or did you install the turbo already?
You'll need to remove the turbo from the manifold, and look at the exhaust inlet. So in your terms, that would be the place between the turbo and the manifold. Look in there.. should be a .63 stamped in there.
Re: (Rob03Pro5)
Yep, it's installed on the manifold.
See, I got this turbo system for free and I'm just trying to figure out what it is so I know what I need to do. If it's indeed a 3431e precision, I think it's too big and I need to downsize a lil bit. I'll also need a kleenex because thats an awfully expensive turbo to get for free
HELLO,GOOD MORNIN'
Re: (da_dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da_dude »</TD></TR><TR><TD CLASS="quote">sc34 = garrett t3/t4 57 trim</TD></TR></TABLE>
thanks i needed to be reapeted
JDMH22HATCH
01-15-2006 04:36 PM
