stock head gasket with .20 overbore?
Old 11-07-2001, 11:02 PM
paulzy's Avatar
Default stock head gasket with .20 overbore?
As you guys know, I have a set of Je pistons and had my sleeves overbored .20 over. Will I have to modify the stock headgasket or can I just slap it on? What I mean is that will I have to cut the the openings in the gasket bigger? I don't want to even **** with the head gasket as I' scared I might **** something up that's more serious. Help me out here fellas...TIA
Old 11-07-2001, 11:07 PM
uglyasscivic's Avatar
Default Re: stock head gasket with .20 overbore? (Slow_ass_4dr)
You will be just fine..20 over just enough to make sure your cylinders are round and clean up anything from your old pistons.
Old 11-07-2001, 11:09 PM
Better than steak
Arturbo's Avatar
Default Re: stock head gasket with .20 overbore? (Ugly assed civic)
Like he said, you can just use the stock head gasket. When dealers rebuild a motor, they bore it .020 over to clean it out and that is the standard bore and within factory specs. So you will be fine with the stock head gasket.
art
Old 11-07-2001, 11:16 PM
dustin's Avatar
Default Re: stock head gasket with .20 overbore? (Arturbo)
I agree with the rest, 20 over is not enough to even matter.
Old 11-08-2001, 12:21 AM
paulzy's Avatar
Default Re: stock head gasket with .20 overbore? (dustin)
alright, thanks, guys
EJ8_Man
06-25-2010 10:16 AM
riceball777
05-17-2004 07:10 PM
migo
07-07-2002 09:54 AM
schwett
04-18-2002 04:19 PM
Quick Reply: stock head gasket with .20 overbore?
