H22 Ticking/Knocking Noise
Old 01-28-2008, 05:47 PM
Excelerate's Avatar
Default H22 Ticking/Knocking Noise
97 Prelude with Mahle 8.5:1 Pistons with Eagle Rods, ARP Head/Main Studs, RC 550's, Cometic HG and a P28 ECU w/ Crome and a Turbonetics Turbo Kit.
The engine has a loud ticking noise at low RPM's that seems to subside with RPM's. It's possible that the engine noise overpowers the noise and it still exists but it's less audible with RPM's. Compression on the engine is good, pretty much 210 across the board with CYL 2 being 200. Visually under the valve cover everything looks fine and a valve adjustment was done. The sound almost sounds like a rod knock but it definitely sounds like it's coming from the head. Also it smokes when fully warmed up sometimes. However, there is no oil in the charge pipes right off the turbo ( I know this can be valve seals or ring lands). I'm trying to figure out this ticking/knocking noise. It's not just an injector ticking; it's pretty loud and more like a knock. And why would this car smoke when warmed up? The car still has great compression and has power. Any help would be appreciated.
Old 01-28-2008, 09:37 PM
p10hlm's Avatar
Default Re: H22 Ticking/Knocking Noise (Excelerate)
auto or manual tensioner?
Old 01-29-2008, 07:13 AM
Excelerate's Avatar
I'm not certain about the tensioner. Why does that make a difference in terms of the noise?
Old 01-29-2008, 08:46 AM
flight50's Avatar
usually when i hear of smoke, its a block problem. like head gasket or fluid entering from somewhere. have you checked in on that.
Old 01-29-2008, 11:24 AM
Excelerate's Avatar
Default Re: H22 Ticking/Knocking Noise (flight50)
Compression is good and there is no oil in the coolant and vice versa.
Old 01-29-2008, 11:39 AM
jdm knight's Avatar
I have a similar problem with my h22 engine; It's a sleeved block with cp pistons and eagle rods. when the engine it's at idle everithing sounds normal but ones you rev the engine at between 1800 an 2000 rpm you can hear a clicking noise but when you go above that rpm the noise seems to dissapear. so far i haven't figure out the problem
Old 01-29-2008, 04:53 PM
jetlude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Excelerate &raquo;</TD></TR><TR><TD CLASS="quote">97 Prelude with Mahle 8.5:1 Pistons with Eagle Rods, ARP Head/Main Studs, RC 550's, Cometic HG and a P28 ECU w/ Crome and a Turbonetics Turbo Kit.
The engine has a loud ticking noise at low RPM's that seems to subside with RPM's. It's possible that the engine noise overpowers the noise and it still exists but it's less audible with RPM's. Compression on the engine is good, pretty much 210 across the board with CYL 2 being 200. Visually under the valve cover everything looks fine and a valve adjustment was done. The sound almost sounds like a rod knock but it definitely sounds like it's coming from the head. Also it smokes when fully warmed up sometimes. However, there is no oil in the charge pipes right off the turbo ( I know this can be valve seals or ring lands). I'm trying to figure out this ticking/knocking noise. It's not just an injector ticking; it's pretty loud and more like a knock. And why would this car smoke when warmed up? The car still has great compression and has power. Any help would be appreciated.</TD></TR></TABLE>
You may have to pull the head and examine the pistons.
https://honda-tech.com/zerothread?id=1901519
Old 04-14-2009, 07:26 PM
H22Accord_guy's Avatar
Check to see if it is your LMAs (lost motion assemblies) i had the same problem
JDM_ego2033
11
04-27-2018 05:52 AM
Excelerate
02-09-2011 04:45 AM
juan400hp
10-16-2009 02:32 AM
v8killaz
05-13-2009 09:41 PM
blackhatchb20
03-10-2006 03:58 AM
Quick Reply: H22 Ticking/Knocking Noise
