greddy turbo timer help
Old 09-09-2006, 03:31 PM
petergriffen's Avatar
Default greddy turbo timer help
ok this is how i have it spliced in and it still wont keep my engine on .ithe timer just turns or with the rest of the car but if i put my key back in the on position the timer comes back on and then i will start its count down but the engine is already off and i keeps all my electronics on like dash lights and console lights and they will go off when the count down is over. please help this is quite frustrating.
-red on timer to solid white wire on ignition
-blue on timer to solid yellow wire on ignition
-green on timer to black & yellow wire on ignition
-black on timer to ground
Modified by petergriffen at 7:42 PM 9/9/2006
Old 09-09-2006, 03:37 PM
SovXietday's Avatar
Default Re: greddy turbo timer help (petergriffen)
You probably have it wired to the starter, and not the "ON" wire.
Make sure you've installed it to the "on" wire and not the starter wire, both will show 12v when the key is in the "on" position. Just look at your starter to find out what wire not to tap.
Old 09-09-2006, 03:42 PM
Default Re: greddy turbo timer help (SovXietday)
ok i edited my post to show where i have my wires running
Old 09-09-2006, 08:37 PM
SovXietday's Avatar
I just wired mine today, that's the only reason I know.
However, my car isn't here, so I can't go and look at it for you. Just double check your wires and check their connections.
Old 09-09-2006, 09:02 PM
will do bu t i havew to work a bunch next week
Old 09-09-2006, 09:04 PM
siblues's Avatar
What car is it?Year and model?
Old 09-09-2006, 09:13 PM
Mr. Badwrench
boostedcivicsir's Avatar
Default Re: greddy turbo timer help (siblues)
Old 09-10-2006, 01:43 PM
Default Re: greddy turbo timer help (boostedcivicsir)
the car is a 95 ls interga
Old 09-10-2006, 03:29 PM
SovXietday how do you have yours spliced in. what color wire on the timer and what color wire on in the car.
Old 09-11-2006, 07:35 AM
is there another wire the green on on the timer should go to? also i just remebered that on the timer u have the thicker red wire. on mine the thicker red wire is spliced into two samller wires. now i got my turbo timer used from some one on here and i think they just did that to lenghten the wire but do u think that this could be some of my problem?
Old 09-14-2006, 09:03 PM
ok checked the starter and its not wired to that. what could it be?
Old 09-17-2006, 10:12 AM
its still not working!!! this is frustarting
turbob16a522
07-03-2005 08:49 AM
skyman88
07-19-2004 11:32 AM
Superorb
05-27-2004 03:21 PM
sporkcrx
06-18-2002 01:28 PM
b18tdelsol
06-07-2002 12:47 PM
Quick Reply: greddy turbo timer help
