Greddy Turbo CEL
Old 08-31-2002, 11:11 PM
Night_Minx
Guest
Posts: n/a
Default Greddy Turbo CEL
I jsut put on a greddy turbo kit on a 96' SOHC d16y8 civic:
-NO BOV
-5 psi setting
-frog engine controls obdII to OBD I wire harness
-94 D16z6 ecu
Car ran fine naturally aspirated, then i put ont he kit, wired it up. Idles fine, no leaks, throws a CEL and the light on the dash and the dome light pulse from full brite to slightly dim. The lbue box light stays on, but pulses green. Should this alwasy be solid green?
Old 08-31-2002, 11:15 PM
New User
R Kincaid's Avatar
Default Re: Greddy Turbo CEL (Night_Minx)
Try putting back in your obd2 ecu and see what happens.
robert
Old 08-31-2002, 11:19 PM
Night_Minx
Guest
Posts: n/a
Default Re: Greddy Turbo CEL (R Kincaid)
The greddy blue box is wired intot he OBDI conversion harness. Without the harness, no blue box, but im going to try it and see what happens at idle
Old 08-31-2002, 11:21 PM
New User
R Kincaid's Avatar
check the CEL code.
Old 08-31-2002, 11:23 PM
Night_Minx
Guest
Posts: n/a
can you tell me if the BLUE BOX led is supposed to be solid green?
Old 09-01-2002, 06:21 AM
IMPORTDYNAMICS's Avatar
mine blinks on the gsr kit
Old 09-01-2002, 06:45 AM
Night_Minx
Guest
Posts: n/a
heres the code, 2 flashes, then 5 flashes of the CEL light. THis is an OBD I ecu on a OBD II car with adapter harness, i dont know if these codes will even read properly. ANyway, can someone tell me what they mean for a OBDI civic EX?
Old 09-01-2002, 08:25 AM
98civicEX's Avatar
check it again, there is no 25...make sure it's 2 slow and 5 fast flashes...also wait after that as well, you may be throwing more then one code.
Old 09-01-2002, 11:34 AM
98civicEX's Avatar
Default Re: Greddy Turbo CEL (98civicEX)
any update on this?
Old 09-01-2002, 11:35 AM
Dr. Blingonian's Avatar
Bill, I think I know what your problem is. First of all, you don't have a VR6. Second of all, you put a turbo on your non VR6 motor instead of a Vortech supercharger.. damn white people.
Old 09-01-2002, 01:01 PM
Night_Minx
Guest
Posts: n/a
Im FuXored
I took the kit off, hopefully it will work like it did before. Nitrous was so much easier.
Old 09-01-2002, 01:48 PM
Accord94DX's Avatar
Default Re: Greddy Turbo CEL (Dr. Blingonian)
whatever, Cracka.
Old 09-01-2002, 01:49 PM
You took it off already? Just until the intercooler setup arrives? Dude, try having connelly swap that ecu out with a different OBD1 ecu at honda. That thing is kinda wierd the way it will stutter at idle and stuff..
evi1_d
06-29-2004 04:18 PM
dmah
07-14-2003 11:36 AM
tonyxcom
09-09-2002 08:57 AM
jdm civic
06-04-2002 05:04 AM
Quick Reply: Greddy Turbo CEL
