Greddy TD05H-18G turbo wastegate actuator size question
Old 02-18-2008, 12:41 PM
FOC-US2K's Avatar
Default Greddy TD05H-18G turbo wastegate actuator size question
Hello all, I have a greddy turbo kit that i am going to putting on my jdm gsr motor. From what I have found so far I know that my motor is 10.6:1 compression and that the stock wastegate on this greddy TD05H-18G turbo is 0.50-0.60kg/cm2 thats 7.5 to 8.5 psi. what i was wondereing if there is any other wastegate that I could use with this setup to lower the spring pressure to more like 5-6psi and control it using the boost controller from there.
Old 04-22-2008, 04:30 PM
95 civic turbo_gsr's Avatar
Default Re: Greddy TD05H-18G turbo wastegate actuator size question (FOC-US2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOC-US2K &raquo;</TD></TR><TR><TD CLASS="quote">Hello all, I have a greddy turbo kit that i am going to putting on my jdm gsr motor. From what I have found so far I know that my motor is 10.6:1 compression and that the stock wastegate on this greddy TD05H-18G turbo is 0.50-0.60kg/cm2 thats 7.5 to 8.5 psi. what i was wondereing if there is any other wastegate that I could use with this setup to lower the spring pressure to more like 5-6psi and control it using the boost controller from there.</TD></TR></TABLE>where did you find the info on the wastegate? i had talked to greddy and they told me it was an 11psi spring.
Old 04-24-2008, 11:02 AM
Default Re: Greddy TD05H-18G turbo wastegate actuator size question (95 civic turbo_gsr)
bump...........
Old 05-05-2008, 01:13 PM
is that correct??
Old 05-08-2008, 11:40 PM
still need help
Old 09-26-2014, 05:01 PM
pamitar101's Avatar
good question how much psi is on the stock wastegate ? 7 or 8 psi my car has an 18g on it and im boosting at 12 to 14 psi on the stock wastegate with no boost controller somethings wrong ? im also getting what feels like boost cut at about 4500 rpms at WOT but if i only push the pedal half way and keep boost under 10 psi i can rev through fine any ideas ?? and yes im running a 3 bar map sensor and my ecu is chipped for it i was thinking a bad wastegate actuator......
Old 09-26-2014, 05:10 PM
Who is Mr Robot?
wantboost's Avatar
A 6 year old thread... Really?
Old 09-26-2014, 05:24 PM
pamitar101's Avatar
would u have rather me start a new on dealing with the same question ******
Old 09-26-2014, 05:39 PM
I never narc'd on nobody!
NotARaCist's Avatar
No, we would rather you do your research.
Available in 4 sizes and various spring rates.
There is no "one size fits all" answer.
Old 09-26-2014, 05:56 PM
pamitar101's Avatar
i did research couldent find an answer so i brought back an old tread
Nisif
06-26-2013 11:20 AM
civicsaremean
05-28-2007 07:15 PM
rice a roni
01-06-2004 03:23 PM
speedy108
07-18-2003 06:51 AM
Tetsuwan Atomu
11-15-2002 12:05 AM
Quick Reply: Greddy TD05H-18G turbo wastegate actuator size question
