GReddy PRofec e-01 Boost Controler ! I think i WANT ONE !!
I WANT ONE.. and i was jsut about to buy my AVC-R !!
this boost controler rocks... anyone used one yet ?
or got any more info on them ??
http://www.perfectrun.com.au/real_si...rprofecE01.htm
This latest model boost controller features following things.
* EL large screen to check all the information accurately.
* High sensitive pressure sensor measures up to 300 kpa of boost.
* Compact solenoid valve allows you to install it anywhere you want.
* Boost control function can be chosen from AUTO or MANUAL mode.
* To obtain steady boost pressure, this boost controller features GAIN function.
* Start-Boost-function allows you to adjust how quickly you want that boost.
* By inputting individual boost correction on each engine rpm, you can set boost more precisely.
* Peak-Hold-function shows maximum boost in the screen, which have been recorded so far.
* Warning-function alarms you by LED and beep sound when the actual boost becomes over the set boost.
* Limiter-function decreases boost to the point you set when the actual boost becomes over the warning boost.
* Each data and program are recorded in SD card. It enables the system to be upgraded in the future.
* By using USB cable (not included in the kit), this boost controller can work with GReddy e-manage. Even if you don't have lap-top computer, you can set the data of e-manage and also save it by using the hand-set.
* All the data on the screen can be recorded and you can play-back them later. MAP-trace-function of e-manage can be recorded and played-back as well.
* If you purchase an optional pressure sensor harness, you can use the pressure sensor in this kit with e-manage, etc...
Re: GReddy PRofec e-01 Boost Controler ! I think i WANT ONE !! (BLKCRX)
How much does that thing cost though? I'm in it for simplicity.. Profec B for me!
Re: GReddy PRofec e-01 Boost Controler ! I think i WANT ONE !! (B00STeD)
iv got a price of Aust$1198 so around $600 US
i have no idea if thats a good price or not.. but yeah that price came from
http://www.perfectrun.com.au/perform...rprofecE01.htm
maybe we can buy a few units and do a group buy on them !!
i want one this week ! eheh as i was just about to buy a avc-r !!
Regards James
Will you make something up for me please?
Re: GReddy PRofec e-01 Boost Controler ! I think i WANT ONE !! (4 Stroke)
Stuff like that attracts thieves, especially if mounted like that!
Profec B for me too Cheap, easy to use, what else could you want?
New User
Re: GReddy PRofec e-01 Boost Controler ! I think i WANT ONE !! (ijjz)
Hey, look, its the GReddy AVCR OSOWT (on steriods overflowing with technology)! I'll stick with the Profec B...
Re: GReddy PRofec e-01 Boost Controler ! I think i WANT ONE !! (VaporTrail)
I agree With VaporTrail I would't trade anything for my Profec B.
And why you ask.... Well its just too easy to use...
Adi
Re: GReddy PRofec e-01 Boost Controler ! I think i WANT ONE !! (newgsr)
Well, greddy is hoping to make these units available in about a month or two. And the price is going to be around $600 so that is the info I was able to get. but I know a website that gets things from Japan and that site got the e-manage like 6 months before us so they will probablly offer it over there, I'll let everyone know.
Later,
Sean C.
Later,
Sean C.
too expensive...takes up too much space just for a boost controller...profec B!
Re: GReddy PRofec e-01 Boost Controler ! I think i WANT ONE !! (MiraiZ)
well the only reason i wanted the AVC_R is because you can change the amount of boost per gear... or per rev's ! and untill now the avc-r was the only boost controler that did that....
but yeah.. i got my tax return money so eheh i think ill splash out and buy this new toy !!
Regards James
Regards James
Re: GReddy PRofec e-01 Boost Controler ! I think i WANT ONE !! (BOOSTINSI)
Im actually using one...we just installed it last night. I havent made the pod to mount it yet since I dont like the whole sittin on a bracket look. Its pretty cool and it has all sorts of features. its not that big, it's pretty nice in my opinion.
Re: GReddy PRofec e-01 Boost Controler ! I think i WANT ONE !! (RyanAutry)
Where can i get this for 510 shipped? the best price i found was 540 something but im jewish so 30 bucks ill save
