Greddy boost gauge??? - Honda-Tech
Old 07-27-2003, 08:53 AM   #1
Default Greddy boost gauge???
I was recommended by some friends to get a greddy or apexi boost gauge instead of autometer if I wasn't pinching pennies, so I went ahead and ordered the greddy boost gauge... on the website it's really hard to get a close look at the boost gauge... is my gauge the one everyone receives?... the gauge only goes up to 2.0 and is in kg/cm2 (squared) units... I was expecting lbs/in2. Are all greddy gauges like this??? do any of the greddy boost gauges come in psi units? Also, what is the conversion. how many psi of boost is 0.5 kg/cm2.... 1.0 kg/cm2.... 1.5 or 2.0 kg/cm2? Should I keep this gauge, or send it back? I guess this is probably a newbee question, but I would appreciate any help you guys can give me...
Thanks in Advance,
Zack
92TEGsrSC is offline   Reply With Quote
Old 07-27-2003, 08:59 AM   #2
Default Re: Greddy boost gauge??? (92TEGsrSC)
Yes. I believe none of them are in psi. It's cool you know, but when it comes to tuning and looking for advice, it just takes another step to convert it.
I have the AutoMeter Boost gauge and it works really well, showing up to 20 psi of boost and 30 thingies of vaccum.
Aiyoko Turbo is offline   Reply With Quote
Old 07-27-2003, 09:03 AM   #3
2lowintegra's Avatar
Default Re: Greddy boost gauge??? (Aiyoko Turbo)
1bar is 14.5psi....
2lowintegra is offline   Reply With Quote
Old 07-27-2003, 09:04 AM   #4
AcuraFreak's Avatar
Here ya go pretty simple enough:
.4Bar (5.8psi), .6Bar (8.7psi), .7Bar (10.2psi), .8Bar (11.6psi) .9Bar (13.1psi), 1.0Bar (14.5psi), 1.1Bar (16.0psi)
AcuraFreak is offline   Reply With Quote
Old 07-27-2003, 09:10 AM   #5
Thanks a lot guys... I just looked on Apexi's website and it says you can get their Mechanical boost meters are available in PSI and KPA... which are better, mechanical or electronic? Also, does Greddy also offer in PSI and KPA for mechanical? what is your guys opinion on this?
Old 07-27-2003, 09:34 AM   #6
Default Re: (92TEGsrSC)
i use a mechanical, because i heard it was easier to install, but i don't know anything about the electrical, so i guess im lost there.
Old 07-27-2003, 10:46 AM   #7
bluebullet's Avatar
Default Re: Greddy boost gauge??? (2lowintegra)
Actually to get technical 1 bar = atmospheric pressure = 14.7 psi
bluebullet is offline   Reply With Quote
Old 07-27-2003, 12:25 PM   #8
ek9vboi
Guest
Posts: n/a
is there a BIG difference in what kind gauge company it is? in my opinion, they are all the same, work the same....just different looks. i got carbon fiber autometer gauges and they lookin tyte in tha nite.
Old 07-27-2003, 12:35 PM   #9
vtec.dc2's Avatar
.1bar = 1.422334331psi
its not that bad once you use it.. pressure won't jump all over the place.. readings in bar matches standart wasteage spring setting anyway..
vtec.dc2 is offline   Reply With Quote
Old 07-27-2003, 12:53 PM   #10
maddog20's Avatar
Greddy boost gauge is not in BAR it is Kg/cm2 1=14.22
maddog20 is offline   Reply With Quote
Old 07-27-2003, 02:26 PM   #11
Elite Hatch's Avatar
Default Re: Greddy boost gauge??? (maddog20)
Quote:
Same thing bro
Elite Hatch is offline   Reply With Quote
Old 07-27-2003, 04:09 PM   #12
maddog20's Avatar
Nope, not that it is big deal but a BAR is 14.7 psi while kg/cm2 is 14.22psi
Old 07-27-2003, 07:16 PM   #13
Default Re: (maddog20)
you make a good point. nearly exactly the same tho I am very suprised that they are indeed not the same
Old 07-27-2003, 07:21 PM   #14
maddog20's Avatar
LOL! sorry not trying to be ****! But every tenth counts especially on stock bottom end KABOOOOM!
Old 07-27-2003, 07:30 PM   #15
vtec.dc2's Avatar
thats a good point.. although i used kg/cm2 which i though was the same as bar..
so its .1 kg/cm2 = 1.422334331 psi
Old 07-27-2003, 07:41 PM   #16
maddog20's Avatar
try this to help you with conversions
goto http://xtronics.com/reference/convert.htm
Compression values of my EUDM Type R sylvain Acura Integra Type-R 4 04-11-2005 10:11 AM
kg/cm Bar and pounds. Whats what? 1quickvr4 Forced Induction 1 10-29-2004 07:37 PM
FS: Blitz Boost Gauge Black Face kg/cm2 KoRE For Sale 5 02-16-2003 09:25 PM
Ideal Oil Pressure gauge readings? degradated Forced Induction 2 10-29-2001 08:04 PM
Greddy Oil pressure gauge degradated Forced Induction 2 10-28-2001 06:51 PM
Tags
05, 15, 87, apexi, bar, boost, buy, convert, europe, gauge, greddy, kg, mechanical, psi, read
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
