Gooch's-JDM B18C w/ JRSC+LHT build/issue thread
#26
R.I.P. Mark
Re: Gooch's-JDM B18C w/ JRSC+LHT build/issue thread
I think that would be a good idea
plug in the hondata and you can then use it to Diagnosis tool
and start to fix the problems
#27
I had to take off the T/B to set the TPS. It was at .765v (idle) and 4.87v (WOT).
After some adjusting I managed to get it to .54v (idle) and 4.82v WOT)
While doing this I noticed the T/B gasket had a slight fold/tear:
This was the cause of the smoking, I guess some coolant was leaking in and burning off.
1 problem solved. Still having the idle issues. At this point I think it could be a bad 02 sensor or maybe my IACV isn't working. (I've cleaned and checked this multiple times)
I also did a spray test with some engine starter to look for vacuum leaks, nothing.
I checked over the connections again and I'm pretty certain everything is going to the right place*ie no vacuum/coolant hoses mixed up. If I cannot diagnose the idle problem by Friday I will have to pay my tuner for it, which at this point is fine.
#28
You can also use zip ties around all the vacuum lines to secure them to the intake manifold nipples, and replace the brake booster factory clamp with a worm screw clamp. I also noticed you may be using the water injection port on the lht manifold to mount your throttle cable bracket. Maybe try removing that and use some hondabond around the bolt when reinstalling it.
#29
#30
Here are some more pics of the install finished up.
Heat Exchanger mounted: (wound up raising it 1" from where it is in the pic to just below the bumper support)
Hoses routed to windshield washer tank, now my reservoir//degas tank:
Hoses/Reservoir tank with H20 pump in old ac component area:
Hoses routed from engine compartment to fender/bumper area:
H20 Pump 90* to hose tire clearanceits pretty close but it doesnt touch with suspension at max height/min height)
Hose clearance with hood closed:
Water wetter (15%) - Distilled Water (60%) - Anti-Freeze MIX (25%) was obviously too much water not enough antifreeze. DID not pass the freezer test:
Misc hose routing:
and all back together...ready for tuning!
Misc hose routing:
#31
R.I.P. Mark
Congates man happy you got it all sorted out
there is 1 other place they can and will leak
where the bypass bolts to the manifold the bolt closest to the TB does not seal from
the LHT end tank
this is a problem i raised with John @LHT and he said he cant seal it during welding
you just have to put sealant in the thread hole
the LHT end tank
#32
the LHT end tank
the LHT end tank
Looking forward to seeing what power I put down. I ran my setup though Veris' (thanks Veris!!) power calculator. A b18c @8.5psi should make around 240-250. I'm hoping for more, bracing for lower, either way should be more interesting on the road course when I'm no longer getting blasted by stock Subarus and may have a fighting chance.
#33
Back from the tune, All went well, idle is better, smoke is gone.
overall a very nice smooth curve. Car feels much lighter on the street. Still havent really put my foot into it. I get home from the tune (car gets hot now--think I need a better radiator) and find what I thought to be a power steering leak is actually SC oil. Im bummed. Does anyone else have snout leak issues? Is it something that needs to be fixed with the unit off? Is there some thing I can do to put a "band aid" on it? Please advise. Graph below.
#34
Nice graph. Looks similar to mine.
I actually just had my supercharger rebuilt by Stiegemeier. Drove it around the block, light throttle, no boost, and noticed the snout leaking as well. I sent it back to them to fix.
#35
#36
R.I.P. Mark
chart look real good
where did you end up with the Vtec shift point
I hope you can get that seal done under warranty without to much down time
#37
Thanks Brad, Nice graph yourself. Lots a of torque. Did Steigemeier charge you for fixing the snout? Is it all better now? I was debating on doing it myself, or fabricating some sort of reservoir to dump fluid in as it leaks out, but really think I should just let them deal with it.
#38
I think the tuner mentioned the VTEC set point at 3500 rpm(only at WOT), definitely in that range-I haven't had the chance to look at his hondata file yet with the snout seal leak and all...I also had to cancel my trip to the ITR expo this year. What a bummer. Pulled the unit out today and its certainly not a large leak, only under boost. Even though I'm only a month out of warranty I hope they do honor it. The charger maybe has 100 miles on it, and at that, maybe 10 were in boost.. I will know in a couple days.
NOW while the charger is out I'm debating on getting a 3.8 pulley to up the boost a little. Also my 4.0" retained damage on the ribs(that I filed down a bit and painted over) from the poorly packaged shipment from the moron I got it off of on ebay (lied about including injectors and CRV pulley included was a GSR)....If I get a smaller pulley and have more boost, would HAVE to re-tune?
#39
R.I.P. Mark
yeah just about any change is a retune but once you have that first tune the ret are just touch ups as most of the hard work is done
#40
#41
R.I.P. Mark
oh man...Really?, that is a bitch to get to. I think they should have mentioned this in their install. Anyway, a great product with flawless build quality BUT the install instructions and diagram were a bit lacking.. I like the part where they casually mention the $1500 unit I just purchased actually requires a GSR T/B or an additional $200 to work properly. WTF that's more than I paid for the charger kit and its porting/rebuilding and I have to spend even more to make it work...(rant over). ANYWAYS...I will have a look at those bolts. Thanks Grim, you have been a TREMENDOUS help in getting things sorted out.
Im in for 17K so far including motor/box
re the help more than glad to help out
#42
Thanks JDMRACER01 - make sure you double check your gaskets and honda-bond application before installing. If you didnt order the map re-locator from LHT and dont have a spare MAP to block off on the T/B you can order it for 1/3 the price here on ebay (just found it this morning) http://www.ebay.com/itm/ws/eBayISAPI...E:B:SS:US:1123
How did you get it idle better? Just tuning?
Im having the same idle problem, before sending it out for tuning.....
#43
#44
#45
Next time I will just smack myself upside the head and go turbo or just buy a used Ducati and be over it.
#46
Well just got my charger back from Steigemeir. They say they put the unit up to 25lbs of boost and could not get it to leak. (So Im crazy) They say they replaced the front snout seal to be safe and charged me a fraction of the normal price (75$) and $45 to ship it. So I'm out another 125$ and all the time to take out the unit, reinstall, + the $400 I lost since I signed up for a track day and had no car to attend with. I'm going to reinstall it when I get my oil cooler/breather box worked out, drive the **** out of the car for the rest of the year, and look for a CRV pulley to up the boost a bit after the winter. At this rate I figure I'm about $6,000 into this kit (most likely more but I dont want to admit it). I know I could have saved a lot of money but oh well, live and learn.
In comparison on my stock usdm ITR motor i made 285hp @ 12psi with bolt on's with the JRSC/LHT setup, and im now making aprox 295hp @ 6psi with sk2 bolt ons and theres still much more tuning to be done so it should break 300hp. Im retuning the motor with 12psi to see the difference in the power band from the jrsc and the pro charger @ 12psi.
https://honda-tech.com/forums/showth...556604&page=12
http://youtu.be/ImvM5N-H-10
#48
You know this is many of the reasons why i sold my LHT/JRSC race kit and went with the ATI procharger super charger because its a much more efficient and has way less maintenance and install time. Don't get me wrong i liked the low to mid range from the JRSC...
#49
I forgot to mention my new concern of the heat, blow by, and everything else.
I'm piecing together an oil cooler for starters since I can get this in while the blower is off. Should have the main parts today (cooler core, thermostatic plate,) so I will detail that in the next post.
