GoinFast's attempt at "Goin' Fast" - B18C5 10.5:1CR Turbo Project Build - Honda-Tech
Old 03-07-2017, 07:48 PM   #1
Default GoinFast's attempt at "Goin' Fast" - B18C5 10.5:1CR Turbo Project Build
Shot out to Mac @ Speed Trap Consulting
Garrett Ball Bearing "Hunter" turbo
H_A Motorsports on my New S300 v3 installed in one of their P28s
TO BE CONTINUED.................
goinfast is offline   Reply With Quote
Old 03-07-2017, 08:03 PM   #2
boosted94gsr's Avatar
Default re: GoinFast's attempt at "Goin' Fast"-B18C51 10.5:1CR Project Build
What's your setup? I have the same turbo, it's a super fun responsive turbo.
boosted94gsr is offline   Reply With Quote
Old 03-07-2017, 08:35 PM   #3
97 spec B18c-R (bearing went bad) so rebuilt the motor with 10:5:1 c/r
Old 03-08-2017, 07:58 AM   #4
Default Re: GoinFast's attempt at "Goin' Fast" - B18C5 10.5:1CR Turbo Project Build
Good luck with the build.
If finances allow I'll be doing a somewhat similar build here later this year with a bone stock 97 spec B18C5 and a Street X kit with a GTX2863R. Going to keep it 11:1 for maximum response and low end, eventually building a B20 on the side for more displacement.
What are your power goals with the hunter?
Chance EG is offline   Reply With Quote
Old 03-08-2017, 02:35 PM   #5
Love the new title, haha. My goal for my car is to crush muscle car dreams, evos, and buburoos. But really id be happy with 420ish whp and 300 tq
I was going to wait until i got and installed the turbo but heres my run dow of build
1999 Civic Ex (A/C and power steering)
B18c 97 Spec Type R
Stock P73
Engine: shortblock
Micropolished crank
Manley H beam rods
Wiesco 10:5:1 pistons
Golden Eagle block Guard welded in
OEM head gasket
APR rod,main,and head bolts
ACL bearings
New type r oil and water pump
New timing belt
Head: PR3
Factory mild port and polish
Skunk 2 pro dual valve springs
Skunk 2 Lost Motion Assembly
ITR cams
Transmission: S80
Stock Helical Lsd
4.4 Fd
Resurface flywheel
Competition clutch stg 4
Turbo: (all parts are bought, just in transit)
Speed Trapp Consulting "Hunter" Garrett ball bearing turbo, Oil and water cooled
Go Autoworks A/C friendy ramhorn, heat coated and lava wrapped
Go Autoworks 2.5" flarred to 3" downpipe heat coated and lava wrapped
Go Autoworks dumptube, heat coated and lava wrapped
Turbosmart 45 wastegate w/7psi spring
Skunk 2 Alpha 1/2 rad anodized Blk, -6an fitting cooling turbo
Suspension:
Skunk 2 pro v II coilovers
Skunk 2 front and rear Camber kit
Skunk 2 Rear LCA
Skunk 2 Front Upper Strut Bar
Eibach front and rear sway bars
Hardrace rear trailing arm bushings
Hardrace Front LCA
Exhaust:
3" vibrant ultra quiet res
3" vibrant turbo muffler
Brakes:
Wilwood 4 piston front calipers
Wilwood slotted and cross drilled rotors
Wilwood brake booster (not installed yet)
Stop tech stainless steel braided brake lines
Electronics:
H/A motorsports P28 with Hondata s300 v3 with boost by gear
Hondata boost solinoid
Hondata 4 bar map sensor (change to 3 bar)
Wheels:
Stock 1999 Si rims
Old 03-08-2017, 06:12 PM   #6
I'd definitely like to hear an exhaust video after the car is running
Old 03-08-2017, 06:21 PM   #7
Quote:
No Worries, parts are in route and I will update as they come in. I will be installing all myself and using a trailer to take to tuner. I will post vids of my lil street machine on the Dyno.
STAYED TUNED.........
Old 03-08-2017, 07:03 PM   #8
Looks like a legit fun setup. Good luck with the build man. What fuel are you getting it tuned on?
Old 03-09-2017, 08:33 AM   #9
93 oct, its not a drag or track car, just my DD and dream crusher,,,,lol
Old 03-09-2017, 05:35 PM   #10
93h2beg's Avatar
I always felt kind of bad beating up on old school muscle with my lil hondas... I know first hand how much time and money go into those old dinosaurs.
93h2beg is offline   Reply With Quote
Old 03-10-2017, 12:43 PM   #11
Thank speed trapp for putting the turbo the cooling fitting on the 1/2 rad i bought.
Man, im getting excited that parts are rolling in. Ive got like half chub, lmao
B16a Injectors $60 shipped B20vCRX For Sale 3 03-20-2017 07:03 AM
J series Insight Build ChokeOnMySmoke Drag Racing 86 03-16-2017 05:49 PM
JDM P30 B16 rods and pistons $150 shipped B20vCRX For Sale 1 03-13-2017 09:08 AM
EXEDY Clutch Disc HCD040U for Honda Accord dayaftertomorrow33 For Sale 1 02-21-2017 10:08 PM
fs brian Crower valvetrain/ stage 2 na cams vroomvroomjdm24 For Sale 0 02-01-2015 01:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
