defi gauge question
defi gauge question
this is for those with defi gauges or has experience with them in their R.
im looking to get the defi boost and oil pressure gaugedefi link II control unit?
or can i just hook it up to all the appropriate wires and vac lines?
ive hooked up gauges before but never have had to hook them to a unit prior to other things like website states.
im not sure. it says that i need it but i just want to make sure.
thanks.
thanks.
Re: defi gauge question
Defi gauges are very easy to install. Someone who hasnt installed gauges before can do it!
You will need a control unit to run them. You get a record funtion which is cool.
You will need to splice and solder, but only 4 wires from what i remember from the control unit.. Then all you do is plug in your gauges to the CU and there lit. Then plug in your senders and theyre up and running..
Best gauges by far!! I will be getting some more for the crx..
Go for it mate.. You wont regret them
es_squared
07-14-2008 09:36 PM
