FR T67 with SC61 turbine housing can i do it?
I got a full race t3/t67 turbo today from a guy. its not the high output. i have a precision sc61 that took a ****. its my understanding that both of these are .63 ar hot sides, can i bolt the t67 on to the precision sc61 turbine housing, it would save me a **** load of trouble!! .
Re: FR T67 with SC61 turbine housing can i do it? (SPOOLINmatt)
depends on what exhaust wheel is in them. You'd have to measure the wheels and see if they're the same. T3/67 doesn't tell you anything except the compressor wheel size and the turbine housing inlet flange size.
Re: FR T67 with SC61 turbine housing can i do it? (tony1)
you talking about measuring the biggest part of the exhaust wheel and the smallest part.
my sc61 exhaust housing is half way welded to the manifold cause the previous owner broke a stud off and i acquired the manifold and i had the same turbo so for the time being i just left it as is, now the turbo broke and im upgrading and really dont want to go through cutting that **** off and changing to a 4 bolt flange if i dont have to.
NZXTInerTia
05-12-2013 07:10 PM
