found turbo for engine but high mileage on engine can I still turbo?
Location: americas finest, calee fourn ya, united states
found turbo for my D-series engine but I have 170,xxx miles on engine can I still use the turbo on the engine or do I need to buy another engine? maybe can replace internals. what can I do? Definitely want to get the turbo. what can I do?
Re: found turbo for engine but high mileage on engine can I still turbo? (extra cam needed)
do a compression test and go from there.. if the compression is good and you dont burn oil and **** it will be all good.. i have about 105,000 on my motor and im running 10psi with no problems...
Re: found turbo for engine but high mileage on engine can I still turbo? (oxSLEEPERxo)
+ id do a leakdown just for good measure. Better to do it now than to do it later and maybe miss something. just my .02
Re: found turbo for engine but high mileage on engine can I still turbo? (chihuahuamanx)
A question to add here. I am also planning on adding a modest amount of boost and I will be doing a compression test soon to check my numbers. If the compression test comes back with excellent numbers, would you assume that the rods and bearings are also in the same shape? Do the compression results and the health of these additional parts go hand in hand? My motor is a b18c1 with 146K on the clock, burns a small amount of oil every 3k and seems to be in very good shape for the mileage. I am shooting for 220-250whp. Replies are appreciated. Thanks.
88hbz6
11-25-2008 07:48 PM
